Viewing 15 posts - 1,441 through 1,455 (of 6,239 total)
  • in reply to: http command #13495
    First of all, try sending command from the device data page (in Communicator settings). Provide screenshots if it doesn’t work.
    in reply to: http command #13494
    With DrvHttpNotif you can send any parameters using GET or POST request.
    You should send a command having the code Request and text like
    grp=value1
    value=value2
    in reply to: Export to database #13483
    Use the SQL examples from this link.
    in reply to: Export to database #13482
    Yes, there is ModDbExport module in v6. The module was upgraded and improved.
    in reply to: Button to open a table #13479
    An addition to the above answer: to display a link as a button, set borders and background color if needed.
    in reply to: User management plug in #13475
    If your company (or client) uses Active Directory, it’s possible to integrate it with Rapid SCADA and manage users by Active Directory tools.
    • This reply was modified 2 years, 6 months ago by Mikhail.
    in reply to: User management plug in #13474
    The option to assign a user management plugin is created for future use. The plugin itself has not been developed yet. We will develop it in the future.
    in reply to: cannot get opc da value #13472
    How did you solve this issue?
    in reply to: i can’t open sample example #13471
    Scheme Editor requires WCF to be installed. Check the Windows features as shown here.
    in reply to: cannot get opc da value #13467
    This page also may help.
    in reply to: cannot get opc da value #13466
    Try Solution 1 and Solution 2 described at the bottom of this article.
    in reply to: cannot get opc da value #13464
    Could you copy communication line log here?
    in reply to: cannot get opc da value #13460
    Possible reason is that Communicator works as a service while another app is a desktop application.
    You can try setting username, password and domain in the connection parameters of the OPC device.
    What is OPC DA specification version?
    What is the OPC server you try to connect?
    in reply to: Chart Pro Data Timestamp Metadata #13459
    Thank you for the info.
    in reply to: Api connection #13456
