MikhailModeratorSomething wrong with XSP4 web server.
Post here the version of XSP and the content of the files
/etc/default/mono-xsp4
/etc/xsp4/debian.webapp
/etc/xsp4/conf.d/scada/*_scada
MikhailModeratorIn Linux a path is case sensitive. Try Login.aspx
MikhailModeratorWhat OS do you use?
In case of Raspbian, validate the content of the files
/etc/xsp4/debian.webappAlso you can try http://ipaddress:8084/scada/Login.aspx
MikhailModeratorHow can I specify the register address to which I want to set my values ?
Use Modbus template editor.
Try to send a command from the tab of Communicator. If it doesn’t work, post a piece of a communication line log with the description of the problem.
MikhailModeratorYou need sending commands to a device. First of all, try to send them manually.
For automatic control you need this module.
MikhailModeratorIf Use SCADA-Server checkbox is set on and communication line is bound to server in Communicator settings, the device address is taken from the configuration database (SCADA-Administrator). You can validate that address is actual in SCADA-Server -> Files -> Configuration database -> kp.dat
After editing and passing the database restart Communicator.
You have to change communication channel properties in Communicator and set Master behavior. Do you poll your devices from the PC and need to send collected data to RPi?
MikhailModeratorSchemes were quite slow to design
Definitely 🙂
If you use Wonderware InTouch, why you ask on Rapid SCADA forum?
MikhailModeratorTables with ~100 channels is slower to draw
How much slower? Could you post network tab of Chrome and requests timing?
schemes not used
Do you mean you don’t use schemes?
MikhailModeratorIt includes charts but without scaling and ChartList. The ChartPro and ChartList components should be redesigned to make them fit for tablets.
MikhailModeratorCharts have been added.
Input channel number fully identifies data. If you need device number, you should create additional table in your MySQL database which defines the relations between channel numbers and devices.
Open SCADA-Administrator and look for the formulas of these input channels.
MikhailModeratorAlso, you can try the prototype of the new web app: http://forum.rapidscada.org/?topic=new-web-app-idea&paged=2#post-1362
