Viewing 15 posts - 5,626 through 5,640 (of 6,219 total)
  • in reply to: Alarm via email #1515
    10 min after start Server service. What is in the module log?
    in reply to: Commands in Modbus #1513
    The default password is 12345. Try to enter it and look 🙂
    in reply to: Commands in Modbus #1511
    Go to Commands tab in Communicator and send a command with a number specified in the template. You should see the command in communication line log and in Device Data tab.
    If it works, configure output channels, bind them to a scheme or a table view and send via the web app.
    in reply to: New Web App Idea? #1509
    All the forces are aimed for the development of the new web app. You could use both versions simultaneously while it is not fully ready.
    in reply to: New Web App Idea? #1507
    Hi!
    Chart Pro and Chart List components will be implemented for the new web app within a few months. Probably, they will require new keys, but in case that you already have a license, the new keys will be free for you.
    in reply to: Alarm via email #1504
    Did you enter your valid email account in the device 201 properies in Communicator?
    If not, just double click the device 201 to open them.
    in reply to: Error installing ScadaWeb Win10 #1502
    OK.
    By the way, the new web app beta works on Linux as well as on Windows.
    in reply to: How to control GPIO for raspberry? #1500
    This topic has another subject. Please create a new one. I can’t recommend you a library but I’ll try to help you to establish connection if you post communication line log.
    in reply to: Error installing ScadaWeb Win10 #1499
    Your settings seem OK. Most likely the installer is not enough clever. Please, do manual installation which is described in the appropriate PDF included in the package. It’s quick.
    in reply to: Error installing ScadaWeb Win10 #1496
    Also you need to check that WCF Services -> HTTP Activation feature is installed for .NET Framework 4+.
    Is it installed?
    May be you could publish the screensot of your Windows features window?
    in reply to: Alarm via email #1494
    If emails are sent successfully, you should use Automatic Control Module to send commands automatically according to your conditions.
    in reply to: Alarm via email #1493
    Check that commands are send from Communicator UI.
    Commands:
    1 (binary) – send the notification.
    Command text examples:
    group_name;subject;message
    contact_name;subject;message
    email;subject;message
    in reply to: Alarm via email #1492
    You can add this XML into ScadaCommSvcConfig.xml:
        <CommLine active="true" bind="false" number="12" name="Email">
          <CommChannel type="" />
          <LineParams>
            <Param name="ReqTriesCnt" value="3" descr="Device request retries count on error" />
            <Param name="CycleDelay" value="0" descr="Delay after request cycle, ms" />
            <Param name="CmdEnabled" value="true" descr="Commands enabled" />
            <Param name="DetailedLog" value="true" descr="Write detailed information to the log" />
          </LineParams>
          <CustomParams />
          <ReqSequence>
            <KP active="true" bind="true" number="201" name="Email sender" dll="KpEmail.dll" address="0" callNum="" timeout="10000" delay="200" time="00:00:00" period="00:00:00" cmdLine="" />
          </ReqSequence>
        </CommLine>
    It adds a communication line with device 201 that sends SMS.
    in reply to: New Web App Idea? #1489
    in reply to: New Web App Idea? #1488
    Tested on Raspberry Pi – OK.
