Viewing 15 posts - 4,936 through 4,950 (of 6,219 total)
  • in reply to: Intergration data input into cloud system #3250
    You should use a device like Moxa Nport that initiates a connection with a cloud server by IP or DNS name. After connection is established, Rapid SCADA server polls the devices.
    in reply to: Linux (Centos) #3248
    I like WinSCP for this purpose.
    in reply to: Server unavailabe #3247
    help me for the instalation, on my screen it appears that the file does not exist.
    could make a video about the installation in raspberry pi please!
    If you issue is not similar to the first post here, please, create a new topic and provide more info.
    in reply to: Server unavailabe #3246
    Could you make a list of directories inside /opt/scada ?
    Did you change the default settings of the SCADA-Server app?
    in reply to: Intergration data input into cloud system #3242
    Hi Hakim,
    If you ask about displaying data on arrow indicators, currently it’s a bit tricky. Otherwise, clarify the question.
    See the Manometer example https://rapidscada.org/download/image_pack/image_pack_1.0.zip
    in reply to: Error updating the hourly data #3241
    Please press F12, open the Console tab and make a screenshot of the error details.
    Do schemes work correctly?
    I suppose, some values cannot be displayed and affect other cells.
    in reply to: Chart Pro Hourly versus Minutely Data #3240
    When you open a chart for a period, it downloads all available minute data for the selected channels.
    Zoom operates data that is already loaded without requesting a server.
    Hourly data are used for reports and for table views.
    Talking about charts, in different cases different approaches are optimal. May be there should be settings for this. But the plugin would be too complex. If our users develop more chart plugins, it would be wonderful.
    in reply to: Arduino uno on Rapid Scada #3235
    You have to create an Arduino sketch that supports Modbus RTU or Modbus TCP.
    Example: https://github.com/2mik/arduino-2mik
    in reply to: Rspberry Pi installation #3234
    When you download Rapid SCADA from the official website, there is also Linux version named “Rapid SCADA 5.5.0 Mono”. The manual is inside zip.
    in reply to: Scheme editor (problems) windows 10 #3233
    Open a command line as administrator and execute this magic comamnd:
    CheckNetIsolation LoopbackExempt -a -n=Microsoft.MicrosoftEdge_8wekyb3d8bbwe
    Does it help?
    Currently, you need to change default browser in the system settings to open web page in Chrome. It’s planned to develop an option of the editor to choose a browser.
    in reply to: Intergration data input into cloud system #3232
    Hi Hakim,
    Please provide correct links.
    in reply to: Error updating the hourly data #3231
    The link is related to your Google drive. I can’t open it. You should text here a link of the shared file.
    in reply to: Scheme editor opening in webpage #3230
    The new version of the editor opens a web page. It’s OK.
    in reply to: SQL Export Issues #3222
    SQL executes when data are coming from Communicator, but SCADA-Server saves all data to a disk periodically at the same moment. Value can change several times before saving to a disk.
    in reply to: Scheme editor (problems) windows 10 #3221
    Please try the following:
    Copy the link from the address bar and paste it into Chrome. Does it work? If not, press F12 and copy messages from the Console tab.
