Viewing 15 posts - 4,051 through 4,065 (of 6,218 total)
  • in reply to: Formulas check '-' #5669
    if (CnlStat > 0) …
    Can we use formula to calculate the elapsed time for the channel being in in True State?
    How many times a day a channel may change?
    The simplest approach is:
    1. Create an input channel of Minute real type.
    2. Use a formula Val(101) > 0 ? Val() + 1 : Val()
    where 101 is the source channel that can be 0 or 1
    The formula is calculated every minute for this type of channel.
    But this approach is not accurate.
    can we use formulas to make a digital counter so that we can calculate how many times channel changed from state to another state for example False to True?
    Just choose Switching counter type of the input channel. And it will count.
    in reply to: Unknown device tags #5660
    Configured the aliases in OPC server. Now I have access to them from communicator service and it is now working. I didn´t know that the use of aliases was needed.
    That’s good! Thank you for sharing the cure recipe. OPC is a black box.
    in reply to: All value reset to 0 when device lost communication #5658
    Stop the Communicator service, and use the Generator feature the collect more information how the formula works. The expected and actual results, you need, are not clear.
    in reply to: Unknown device tags #5651
    Is it possible that this tags are blocked to use them outside OPC server?
    May be, but I don’t think so.
    Matrikon also provides OPC Explorer. Try to use it for get data of that tags. Does it work?
    I can connect to your PC remotely to do more diagnostic, however this is a commercial service and I’m not sure that I reach success in fixing this problem.
    I tried restarting communicator and also setting the tag´s names from administrator but still not work.
    Please provide communication line log.
    in reply to: Delete Archived Data #5649
    Yes. Open the archive directories:
    C:\SCADA\ArchiveDAT\Events
    C:\SCADA\ArchiveDAT\Hour
    C:\SCADA\ArchiveDAT\Min
    and delete the unnecessary files. Each file is written for a one day.
    in reply to: Export to Database Module #5648
    Is the “duplicate entry” error critical in your situation or can be ignored?
    in reply to: Unknown device tags #5647
    Could you check if the problem also occurs in case of using Matrikon OPC Simulation Server?
    Despite of the error, a name should be set non empty. Are there tags that can be added with non empty name? What if you save settings and restart the Communicator service?
    in reply to: Ubuntu Installation Forbidden from Apache2 #5646
    OK 🙂
    in reply to: What is "Bound to Server" – Communicator #5641
    OK 🙂
    in reply to: Export to Database Module #5640
    May be you should change cnlmun to cnlnum in the INSERT request.
    in reply to: Set alarm for event #5639
    However, the alarm still plays the old sound file and not the one configured at in the Modules.
    You should ask the module author for the solution. Possibly write to him on GitHub.
    By the way, did you restart the Server service?
    Eg. alarm should play when channel value is 1 but should but play if it goes to 0.
    Create an extra input channel of the calculated type and revert the value:
    Val(101) > 0 ? 0 : 1
    101 is the number of the source input channel
    in reply to: Unknown device tags #5638
    Error check tag type:
    Receiving data from OPC server failed.
    Add the tag manually by specifying its type
    Please provide a screenshot.
    in reply to: Ubuntu Installation Forbidden from Apache2 #5637
    What error do you get in browser?
    in reply to: Set alarm for event #5630
    Also the Notification Plugin plays sound. But an operator must acknowledge an event to set beeping off.
