Viewing 15 posts - 3,901 through 3,915 (of 6,218 total)
  • in reply to: KNX Driver #6080
    Read this as an introduction.
    Then use the existing drivers as templates.
    in reply to: Get time from two channels #6079
    now I only have to eliminate the seconds.
    In this case it’s better to simply use 2 text components close to each other. And “:” between them.
    in reply to: Get time from two channels #6076
    To display:
    Create a 3rd input channel of the Calculated real type.
    Use a formula for this channel. Something like EncodeDate(new DateTime(1, 1, 1, Val(101), Val(102), 0))
    where 101 and 102 are the channels for hours and minutes.
    Set the format of the new channel to Time.
    When the above works, let’s think how to set the time.
    in reply to: Output command value #6075
    Cmd and CmdVal – the both are correct and mean the same.
    in reply to: Output command value #6070
    CmdVal * 1000 is a correct formula for an output channel. What is the issue with it?
    in reply to: Automatic Control Issue #6068
    I can’t download the zip, but I think it’s not necessary. Number of triggers doesn’t matter.
    Let’s choose a one of the following ways:
    1. Create as simple project as possible and find how to reproduce the problem without real devices. So I can do fix the bug on my PC.
    2. Remote trobleshooting as a paid service.
    in reply to: Automatic Control Issue #6065
    Nice screenshot. The configuration looks correct.
    Make sure that you sent configuration to the server, and SCADA-Server was restarted after configuration changed.
    Do other similar triggers work or not?
    Also check the channel 7239 status in the current data file.
    in reply to: channels support array type #6060
    How does it provide data? What communication protocol is used?
    in reply to: Automatic Control Issue #6059
    Please make a screenshot of your trigger settings. And provide ModAutoControl.log
    in reply to: Modbus TCP Server #6058
    Too big packets are not reliable. If you face limits in Modbus Template Editor, this is because of the Modbus standard.
    in reply to: Admin access Remote #6057
    Look for additional details in Agent’s log file.
    in reply to: Admin access Remote #6056
    In the profile settings, set ScadaAdmin / 12345
    You can also check /opt/scada/BaseDAT/user.dat Open it in a good text editor and try to find the above login and password. It must contain them.
    in reply to: Modbus online parser #6050
    I found that offline app somewhere in the internet and haven’t used it any more after developing the web parser.
    in reply to: Modbus online parser #6047
    in reply to: channels support array type #6045
    Please describe your case in details. We can take it into account.
