We need to clarify the issue. Could you provide links tp the screenshots of the settings, describe expected and actual behavior?
Fixed. The problem appeared because the scripts in the editor were not updated. Now these files are replaced in the distributive package without changing version number. You should download it again and update files in
C:\SCADA\ScadaSchemeEditor\Web
C:\SCADA\ScadaWeb\plugins\SchemeEditorThank you.
Check the command type of the trigger (standard or binary).
To avoid infinite loop:
1. You need to create another output channel for the 2nd command.
2. Or check the command value in the trigger.
According to the log file, you can connect to the converter, but there is no response from the device.
Check the following:
1. The device ID is correct (is set to 5).
2. RS-485 wires are correct. Try swapping A and B wires.
I will check it and write here.
MikhailModeratorGood. The fix will be included in the next release. Thank you.
You need to create a command trigger in the module settings. Under this trigger create a command to send “release command”. If you provide screenshots of the settings, I can check them.
MikhailModeratorYou have to set Signal to an empty string. Otherwise the channel gets data from a device.
MikhailModeratorDear Han,
Could you let me know step by step to configure to send a release command?
Please explain your question. What is “release command”?
Could not convert string to DateTime: 1608121200227. Path ‘range.to’, line 1, position 53.
You right, the problem is in format conversion. 1608121200227 is a number while a date string is expected.
Merry Christmas and Happy New Year!
MikhailModeratorWe recently discussed this in Russian forum. Could you use Google Translate starting from this message? Pay attention to the link to a manual which describes how to use nginx as an endpoint. We can continue the discussion here.
Try to get full exception stack where you can see a sequence of exceptions.
What operating conditions are causing this exception?
MikhailModeratorThanks for noticing. It’s very common issue.
Please right click the input channel, open properties and make a screenshot of all channel properties.
MikhailModeratorYou should use the Administrator app. This article may help.
It’s recommended to use Administrator on Windows and upload the project on Linux. -
