June 21, 2021 at 8:51 am in reply to: Same configuration different command frame on Windows and Linux #9116
Please copy the appropriate logs from Communicator.
MikhailModeratorInput channels work as variables.
Output channels don’t store any data. They declare commands.
Use the existing source code as example.
and returns a value as double
What communication protocol is used?
MikhailModeratorMay be it’s better to deploy cheap Linux machine for each customer instead of using the single server.
It’s possible only if you install manually.
In addition to the instruction, you should copy Rapid SCADA files to different folders, create svc_config.xml for each service (example), and update svc_*.bat files to have different services for different instances.
Please send the new and the previous computer code by email info@…
I will check the cause.
MikhailModeratorPerform the settings according to the manual. In case of errors provide screenshots of the settings and error messages.
MikhailModeratorVery interesting.
Please keep the community informed about new developments.
Note that driver and module interfaces may change during the development of v6.
I will do some work on the web
What do you plan to do?
MikhailModeratorDon’t use classic Windows services from v6. Run *App.exe that work on .NET5.
Uploading project function doesn’t work for now. Use these utilities to convert configuration database from XML to new DAT format.
On Linux, open terminal and try that command.
SheetOptions specifies the input parameters for the report. To setup report view, you should configure the report sections. For further questions about Elastic Report, please start a new appropriate topic.
MikhailModeratorIt is sent successfully if the both, returned value and result are true.
