Viewing 15 posts - 2,191 through 2,205 (of 6,242 total)
  • in reply to: Error message xml not found #11465
    The question is duplicated.
    in reply to: Report summary of register values (table & excel) #11464
    If you have issues with displaying the above data, please provide screenshots.
    Can I export this excel data via WebStation?
    Yes, Webstation allows to export historical data to Excel.
    in reply to: V6, communicator ignores bound channel of integer data type #11455
    maybe it should be highlighted in the document regarding these data types
    You right. Currently, the documentation for v6 is not ready. Nuances of the algorithms should be added to the docs.
    in reply to: v6, DrvDsMqtt not publishing anything. #11451
    @zzz, do you get data from Communicator to ScadaServer successfully?
    in reply to: v6, DrvDsMqtt not publishing anything. #11450
    Let me try later today since I have my own Mqtt server locally and on the cloud.
    @kumajaya
    , if you already have tried the MQTT publishing data source, could you share the experience?
    in reply to: v6, DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ? #11449
    Writing of 0 data points completed successfully in 1 ms
    It looks like no channels are associated with the archive.
    in reply to: v6, DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ? #11448
    InfluxDB2 is supported.
    In ScadaServer.txt there are statuses of archives. Is the MinCopy archive displayed as ready?
    In ScadaServer.log how many channels for archiving? For example
    Number of active channels for archiving: 271
    in reply to: V6, communicator ignores bound channel of integer data type #11445
    In my test project, I setup 77 channels, all as Integer type, none got recognized, until they are all set to Double. and they all are immediately recognized by Communicator.
    The Modbus driver uses the double type for all its tags. Channel data type must match a tag data type. The behavior looks as expected.
    Currently all existing drivers use the Double type. However, if someone writes a custom driver, he can use integer tags.
    in reply to: v6, timezone issue #11444
    ScadaCommon.dll is a new name for ScadaData.dll
    You can find new file formats here.
    in reply to: Omron Fins Driver (Ethernet) #11443
    Do you use GitHub? If so, you could add the development to a public repository.
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11442
    For the ScadaWeb project try publishing to a folder.
    in reply to: V6, communicator ignores bound channel of integer data type #11428
    Is it possible to reproduce the issue on the default HelloWorld project?
    Data type of channel and device tag (provided by a driver) must match. It should affect only certain tag. If it corrupt other tags, it may be a bug.
    in reply to: v6, timezone issue #11427
    If you use PostgreSQL archives, pgAdmin converts selected data to local to make it handy for a user.
    in reply to: v6, timezone issue #11426
    It seems that rapidscada is using UTC time to store data
    That’s right. Timestamps converted to local time only in the web application.
    Log files uses the server’s time zone, however, it does not affect the logic.
    in reply to: v6, DrvDsMqtt not publishing anything. #11425
    Screenshots and logs may help.
    I tested the MQTT data source with the following parameters:
    ClientID =
    DataLifetime = 60
    DetailedLog = False
    DeviceFilter =
    MaxQueueSize = 1000
    Password = C8080E774B59B0C6694063BDE2428352
    Port = 1883
    ProtocolVersion = Unknown
    PublishFormat =
    QosLevel = 0
    Retain = False
    RootTopic = Communicator/
    Server = broker.mqtt-dashboard.com
    Timeout = 10000
    UndefinedValue = NaN
    Username =
    Communication channel options:
    ClientID =
    Port = 1883
    Timeout = 10000
    Username =
