Viewing 15 posts - 2,026 through 2,040 (of 6,240 total)
  • in reply to: V584 and V6 at the same computer #11901
    You can install v5 and v6 on the same computer in different locations. But you should stop the services of a one SCADA when another is running, because the services use the same TCP ports.
    in reply to: V6 WebStation #11900
    Language files are located in SCADA\ScadaWeb\lang
    in reply to: Export Table View #11899
    A table view extracts data in exact timestamps. You could configure archives to write data periodically (and on change if needed).
    in reply to: Webstation – localhost #11898
    The installer app creates a new web site that requires port number.
    To use the default port 80:
    Option 1
    In IIS console disable the default web site, and change port number of the Scada site to 80.
    Option 2
    Manually create an application for SCADA within the default web site.
    in reply to: Customization of Scheme titles in browsers #11897
    In case of table views, the title is taken from the Views (Interface) table.
    in reply to: Customization of Scheme titles in browsers #11896
    Set scheme the Title property in the Scheme Editor app when you select a scheme document.
    in reply to: Migrating V5.84 projects to V6 #11895
    There are a lot of differences between v5 and v6 projects. It’s normal to have some questions during conversion.
    in reply to: Migrating V5.84 projects to V6 #11894
    Download the tools from this folder. See ProjConv5to6.zip, HistConv5to6.zip and EventConv5to6.zip
    The project converter archive contains readme.txt
    in reply to: V6 Log – Webstation and Server #11893
    It depends on what application you need to control.
    In case of complex errors, it’s recommended to analyze logs of all applications.
    in reply to: V6 Archieves (minutes/hourly) #11892
    For retrieving raw data from archives, use reports.
    in reply to: V6 Formats – Date and time, Date, Time #11890
    To display current date and time, try the formula Now() or UtcNow(), and set appropriate channel format.
    in reply to: V6 Device types Email 221 #11889
    Email driver for v6 exists and works. Check statuses here.
    in reply to: V6 Status Severity #11888
    Severity, specified for a channel status, will be set for generated events if a channel has that status.
    For now, the web interface uses only main color. The second and back color columns are made for future use.
    in reply to: Web Page View #11882
    The example is for v5. It does not work with v6.
    Use the appropriate web page for v6.
    Open browser tool by pressing F12 and check the actual page URL.
    in reply to: V6 Add device and Add channel under *.tbl #11881
    If there is a question, please clarify it.
