Viewing 15 posts - 1,996 through 2,010 (of 6,240 total)
  • in reply to: V6 – Extra Scheme Components #11970
    Approximately, 1 or 2 weeks. The link will appear on this page.
    in reply to: SMS GSM Cinterion Modem #11969
    Modem should be Siemens C35 compatible.
    For example, we successfully used Huawei E1750
    in reply to: The login page of the web always prompts an error #11968
    What parameter we need to change in the app pool options?
    in reply to: Implementation of “Per Console” permissions #11960
    Hi Louis,
    According to my understanding, the possible architecture is as follows:
    1. Each location is served by a separate Rapid SCADA instance.
    2. We can have the central Rapid SCADA instance on the main server that collects primary data from locations. Or don’t have central SCADA, so the system can be decentralized.
    3. There is a special module, named Rapid Gate, that transfers data between Rapid SCADA instances in the specified directions.
    4. User management can be implemented either by the built-in Rapid SCADA features, or by using an external auth system.
    Please ask related questions to clarify the possibilities of a solution.
    Note: what do you mean by “console”?
    in reply to: SMS GSM Cinterion Modem #11958
    May be you should try to find utilities that send AT commands to modem and test them.
    in reply to: SMS GSM Cinterion Modem #11957
    Dear Han,
    Something wrong in SMS packet. To find a cause, it’s needed to learn SIM808 documentation and make a research. Such work is not included in support.
    I recommend to use Telegram to send notifications. Or use special REST web services.
    in reply to: V6 – Extra Scheme Components #11956
    For version 6 you need the appropriate version of components.
    Extra Scheme Components 6 will be published with the next Rapid SCADA release.
    When the rapidSCADA session is terminated, the data cannot be updated
    It tries to reconnect, but cannot.
    Could modifying some RapidSCADA comm parameters help reduce the chances of it being rejected?
    I suppose, disconnect is initiated by the OPC server. You should ask the OPC server developers why it closes connections.
    in reply to: The login page of the web always prompts an error #11954
    if no one is using it (this is my guess, because it’s just my personal test) Webstation is stopped after 30 minutes
    That’s true. This is how IIS works by default.
    Open IIS management console, find application pool ScadaAppPool advanced options, and try to find a parameter to always run.
    Let us know about the result, please.
    in reply to: rapidscada V6 use CustomPage #11947
    Thank you for sharing the experience.
    JavaScript API version 6 is different from API v5.
    in reply to: SMS GSM Cinterion Modem #11946
    Dear Han,
    SIM808 replies “ERROR” for message list request.
    Did you try to send messages by commands?
    in reply to: V6 WebStation #11945
    Open file as administrator for editing.
    The issue happened the 1st time.
    Do the OPC servers show active connections? How many connections in total?
    What does Rapid SCADA 6 do if an OPC connection is closed by OPC server?
    in reply to: rapidscada V6 use CustomPage #11940
    The Arguments cell should be something like “../../custom/MyPage.html”
    Path = “Test\test”
    Title = “test”
    in reply to: ModDbExport for oracle #11939
    If there is an issue, the error is written in the module log. Could you check C:\SCADA\ScadaServer\Log\ModDbExport*.* ?
