kumajaya
ParticipantKpMQTT + Emqtt + Telegraf + InfluxDB + Grafana:
Will be great if Grafana can access Rapid SCADA database directly.kumajaya
ParticipantWill be great! Can we embed Freeboard inside Rapid SCADA current dashboard?
kumajaya
ParticipantThe dashboard more resource hungry than Rapid SCADA but works 😀
kumajaya
ParticipantOr visualize Rapid SCADA data on Thingsboard dashboard: https://drive.google.com/file/d/1iu7C1IJTgvceWv4o-9pmIizj_fxtT2R3/view
But need MQTT driver change to add message prefix and suffix to reconstruct json formatted payload 🙁
kumajaya
ParticipantThe last release fix the problem. With ThingSpeak help, Rapid SCADA data on home screen looks very nice: https://drive.google.com/file/d/1dm5cWsnaVaxClzg-uqL6XUmPee8KieM1/view
kumajaya
ParticipantI just opened a pull request to force use periode (.) as decimal separator. Please check https://github.com/bersim/OpenKPs/pull/5/files . Thank you.
kumajaya
ParticipantHi Mikhail, I found nothing in MQTT driver source code but plain double to string conversion https://github.com/bersim/OpenKPs/blob/1c0009699895bcc886c31169565681e76cacfae9/KpMQTT/MQTTPubTopic.cs#L62 and https://github.com/bersim/OpenKPs/blob/1c0009699895bcc886c31169565681e76cacfae9/KpMQTT/KpMQTTLogic.cs#L357 for publishing and plain string to double conversion (with regex filter for commas) https://github.com/bersim/OpenKPs/blob/1c0009699895bcc886c31169565681e76cacfae9/KpMQTT/KpMQTTLogic.cs#L238 for subscribing. Is this related to development environment locale setting? Since I don’t have development environment for building MQTT driver from source, if don’t mind please rebuild MQTT driver on yours machine and share the resulted binary to us. Thanks in advance.
kumajaya
ParticipantThanks for your quick response Mikhail. Rapid SCADA data on Cayenne dashboard look really nice actually https://drive.google.com/file/d/1ZKeZvDKcrqf7rO28j8QGViMIN0yhSuxZ/view
This reply was modified 8 years, 10 months ago by
kumajaya.
kumajaya
ParticipantHa..ha.. Thanks Mikhail.
