mitesh
ParticipantHi Mikhail,
I am not getting anything after setting input channel type to Real and formula to EncodeDate(DateTime.Now) and format to Date and Time.
mitesh
I want to Display the exact date and time when event occurs. In Administrator i have selected channel type as hourly real. i am getting wrong date (30/12/1899) and time (00.00.00). Please help me to display exact date and time.
Ex: Event Date Time
High Temperature : 70°C 27/02/2019 10:35:40
mitesh
I got it and Thank you for your support.
mitesh
In Web Application i clicked Collapse menu option. so now i am not able to see Main menu, views,server equipment and demo options. could you please help me to recover that options.
Regards,
MiteshDecember 14, 2018 at 1:18 pm in reply to: How to get the data which automatically sent by the devices? #4736mitesh
I want to send data from my remote devices to scada in http format and that data should be stored in database. Please Help me out.
mitesh
I have Created input Channel but what formula should i use to get the required time for the higher value in a day.
mitesh
Have you already created an input channel that stores max value of a day?
yes, I have created an input channel that stores max value. But i want to know the time in that day for high value in Elastic reports.
mitesh
I am getting every hour data in Elastic Reports. But i just want to create Elastic Reports(Excel) in such a way that it should contain only Higher value data in a day with time.
please help me to come out from this.
January 2, 2018 at 5:30 am in reply to: Comparing the previous value of channel with the current value of same channel #3000mitesh
ParticipantHello Mikhail,
I want compare previous value of channel-1 with the current value of channel-1.. and after comparison i want to store the highest value.
(pre_data_cha1 > cur_data_cha1) ? pre_data_cha1 : cur_data_cha1. I got answer for this by your reply Val() > Cnl ? Val() : Cnl.
now i want to save that highest value in excel sheet with time. how to show time in excel sheet.
mitesh
How to create a column in excel (Elastic Reports) that contains time of perticular Event.
December 29, 2017 at 9:33 am in reply to: Comparing the previous value of channel with the current value of same channel #2984mitesh
ParticipantThank you Mikhail 🙂
mitesh
Any solution for changing the fore color of dynamic text for channel 1-9 compaing the value with channel 10 if it cross above the value of channel 10.
mitesh
ParticipantHi Mikmail,
Yes i want change the fore color of dynamic text
mitesh
I got change of text color in events but i didn’t got on Dashboard Dynamic Text. I want to change the dynamic text color of channel 1 when the value of channel 1 goes high or equal to channel 10.
If channel 1 dynamic text color is Blue, if it is greater than or equal to channel 10, i want channel 1 dynamic text color change to red.
with the above solution i get color change in events.
mitesh
ParticipantHello,
I have 10 input channels and i want to change the text color of channel 1 to 9 data when the value of channel 1 to 9 is equal to or greater than the data of channel-10.
Example: Channel-1 channel-10 alert
value –> 620 800 no need to change the color of the text
value –> 850 800 change the color of text -
