peter_f
ParticipantIn this directory
C:\SCADA\ScadaServer\Mod
are the following files:ModActiveDirectory.dll 11/15/2021
ModDbExport.dll 11/15/2021
MySql.Data.dll 04/26/2018
Npgsql.dll 07/19/2020
System.Buffers.dll 07/19/2020
System.Memory.dll 04/17/2019
System.Numerics.Vectors.dll 07/19/2017
System.Runtime.CompilerServices.Unsafe.dll 09/18/2018
System.Threading.Tasks.Extensions.dll 11/29/2018
System.ValueTuple.dll 05/15/2018I hope, this is the information you need.
I was unable to make a screenshot. That means, it ist possible to make a screenshot, but i cant´t place it in the trxtfield here.peter_f
ParticipantMaybe it will be helpfull o post the logfiles (just the last entrys)
ScadaCommSvc:
2023-07-04 14:02:59 <SBRGVMAPS0098><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2023-07-04 14:03:01 <SBRGVMAPS0098><SYSTEM><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2023-07-04 14:03:01 <SBRGVMAPS0098><SYSTEM><ACT> Disconnect from SCADA-Server
2023-07-04 14:03:01 <SBRGVMAPS0098><SYSTEM><ERR> Unable to start operation due to SCADA-Server communication error.
Delay before trying again
2023-07-04 14:03:11 <SBRGVMAPS0098><SYSTEM><ACT> Connect to SCADA-Server “localhost”ScadaServerSvc
2023-07-03 16:16:40 <SBRGVMAPS0098><SYSTEM><ACT> ScadaServerService 5.1.4.2 is started
2023-07-03 16:16:40 <SBRGVMAPS0098><SYSTEM><EXC> Error loading module from the file C:\SCADA\ScadaServer\Mod\ModDBExport.dll: Could not load type ‘Scada.Server.Modules.ModDBExportLogic’ from assembly ‘ModDbExport, Version=5.1.0.1, Culture=neutral, PublicKeyToken=null’.
2023-07-03 16:16:40 <SBRGVMAPS0098><SYSTEM><ERR> The configuration database in DAT format directory does not exist.
The interface directory does not exist.
The archive in DAT format directory does not exist.
The archive copy in DAT format directory does not exist.
2023-07-03 16:16:40 <SBRGVMAPS0098><SYSTEM><ERR> Normal program execution is impossibleSCADA-Server
Started : 03/07/2023 16:16:40
Execution time : 00:00:00
State : error
Version : 5.1.4.2Connected Clients
NoBefore I copied the old Data to the new installation, I could start the server and there was the sample project. Now I just can´t log in.
peter_f
ParticipantHello,
I have carried out the installation as suggested and imported the old project in the administrator.
All devices, communicator lines and objects have been transferred correctly, as far as I can see. The points I created, such as users, additional units and quantities, were also transferred.
When I try to log in, I get an error message: Server is unavailable.
In the instance status, I see Error for both the server and the communicator. Restarting the server does not bring any change.Have I overlooked something?
Peter
peter_f
ParticipantHi, obviously I failed to send the answer to the last question.
There are about 750 input chanels, no output chanels, and about 40 devices.
Is that a problem?
How do I proceed now?
Thank you for your helpPeter
peter_f
ParticipantIts not so easy, because there are different versions for the different applications
webstation is 5.0.3.0
administrator is 5.0.0.2
communicator is 5.1.0.0
Does the path suggested in the link work in this constellation? I can’t find a projects folder in the linked document either. Where can I find the configuration to load into the new project?
peter_f
ParticipantHi
I want to move Rapd Scada to another server. At the same time I want to update to the latest version. This is described in the documentation and should hopefully not be a problem. I use two paid plugins. Can I also move them, or do I have to purchase them again?Thanks
Peterpeter_f
ParticipantThis is my problem too. I changed the culture to en-US with no effect. pt-BR is the same. Is there an other point where I have to do something?
peter_f
Participantthis is the link
http://forum.rapidscada.org/?topic=dashboard-export-to-pdfpeter_f
ParticipantHi Mikhail,
This is the topic I refered.Mikhail
If I open a dashboard http://demo.rapidscada.net/plugins/Dashboard/Dashboard.aspx?key=allusers-DashboardDemo using Chrome on Android 5, export to PDF works.
Wenn I klick the Link rapid scada opens with the dashboard “DashboardDemo” without need to fill in a password. Exact that is what I want do do. Rapid scada should be part of a Webpage where some informations are providet. User should see the Dashboard without need to logon.
peter_f
maybe I described my question not exact. The question is, how can I provide access to a dashboard or to a table without neding a password. My idea was that there should be a way to start rapid scada and write username and password with the page view. ( i.e. ???/scada -user:guest -password:12345) You did that in your example in #2458.peter_f
apparently it is my mistake that i payed attention to this. In the table it works with the wrong ID. Now it works and I have to thank you.
Peterpeter_f
I think it is helpful to say that table & chart work if they are startet from the Menu. In the dashboard table works fine, but there is no chart.
you should see the page on this URL this will be better than any explanation:
fischerp.selfhost.eu:8888/scada
(The Link is just temporary working)This is the dashboard configuration
<?xml version=”1.0″ encoding=”utf-8″ ?>
<DashboardConfig>
<DashboardOptions>
<Name>Temperaturen</Name>
<ColumnCount>2</ColumnCount>
<AspectRatio>1.33</AspectRatio>
</DashboardOptions>
<Widgets>
<Widget type=”Chart” cnlNums=”601,602,603,604,605″ viewIDs=”2,2,2,2,2″ period=”1″ />
<Widget type=”Chart” cnlNums=”601,602,603,604,605″ viewIDs=”2,2,2,2,2″ period=”7″ />
<Widget type=”CurData” cnlNums=”601,602,603,604,605″ viewIDs=”2,2,2,2,2″ />
<Widget type=”CustomUrl” url=”http://sankey-diagram-generator.acquireprocure.com/” />
</Widgets>
</DashboardConfig>I hope this is the relevant part of the logfile
2017-10-31 21:51:26 <LENOVOSFF><DefaultAppPool><ACT> Initialize common web application data
2017-10-31 21:51:26 <LENOVOSFF><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2017-10-31 21:51:26 <LENOVOSFF><DefaultAppPool><ACT> Refresh the tables of the configuration database
2017-10-31 21:51:27 <LENOVOSFF><DefaultAppPool><ACT> Fill input channels properties
2017-10-31 21:51:27 <LENOVOSFF><DefaultAppPool><ACT> Fill output channels properties
2017-10-31 21:51:27 <LENOVOSFF><DefaultAppPool><ACT> Fill input channel statuses properties
2017-10-31 21:51:27 <LENOVOSFF><DefaultAppPool><ACT> User information has been added. IP address: 192.168.2.128. Session: fqykwmnz3cnft4tdpqyljyde
2017-10-31 21:51:35 <LENOVOSFF><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.128
2017-10-31 21:51:35 <LENOVOSFF><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.128. Session: fqykwmnz3cnft4tdpqyljyde
2017-10-31 21:52:21 <LENOVOSFF><DefaultAppPool><ACT> Check “Dashboard” registration:
Registration key is valid
2017-10-31 21:52:30 <LENOVOSFF><DefaultAppPool><ACT> Check “Chart Pro” registration:
2017-10-31 21:52:31 <LENOVOSFF><DefaultAppPool><EXC> Error getting view with ID=2 from the cache or from the server: Value cannot be null.
Parameter name: viewType:
System.ArgumentNullException: Value cannot be null.
at Scada.Client.ViewCache.GetView(Type viewType, Int32 viewID, Boolean throwOnError)
2017-10-31 21:52:32 <LENOVOSFF><DefaultAppPool><EXC> Application error:
Scada.ScadaException: Error getting view with ID=2 from the cache or from the server: Value cannot be null.
at Scada.Web.Plugins.ChartPro.WFrmChartPro.Page_Load(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Page: http://192.168.2.21/Scada/plugins/ChartPro/ChartPro.aspx?cnlNums=601,602,603,604,605&viewIDs=2,2,2,2,2&&period=-7
User: admin
2017-10-31 21:52:33 <LENOVOSFF><DefaultAppPool><EXC> Error getting view with ID=2 from the cache or from the server: Value cannot be null.
2017-10-31 21:52:33 <LENOVOSFF><DefaultAppPool><EXC> Application error:
Page: http://192.168.2.21/Scada/plugins/ChartPro/ChartPro.aspx?cnlNums=601,602,603,604,605&viewIDs=2,2,2,2,2&&period=-1
User: admin
2017-10-31 21:52:44 <LENOVOSFF><DefaultAppPool><EXC> Error getting view with ID=2 from the cache or from the server: Value cannot be null.
2017-10-31 21:52:44 <LENOVOSFF><DefaultAppPool><EXC> Application error:
server: Value cannot be null.Parameter name: viewType
Page: http://192.168.2.21/Scada/plugins/ChartPro/ChartPro.aspx?cnlNums=601,602&viewIDs=2,2&&period=-2
User: adminHere you can find the screenshots.
http://www.mediafire.com/?2sr31bh2kkk6dPeter
peter_f
this sounds very interesting. Do you have my email address? I hope you can see it in my profile. Otherwise you could post yours here. I dont want to write my address here, I’m afraid about getting lot of spam by give out my address to public.
Than i can tell you my vision about the way that feature should work. After that you should be able to estimate the price.peter_f
ParticipantHere you can find a typical sankey like I would use.
https://www.dezem.de/sites/default/files/pictures/sankey.png
What I suggest is that I can give selected values labels like source and target. So I can say that a value flows from [source] to [target]. This will build a tree that shows how energie is providet and how it ist used.
A typical way to fill such a diagramm ist a table like this:source,target,value
Wirklast,atlas,150
atlas250,zm6-7120,50
atlas250,zm6-7103,50and so on…
In the example you see left the required energie (Wirklast) for the compressed air production. Next you see, that there are two engines(Atlas 160 & Atlas250) to do this. They share the energie. Both of them provide some “customers” with air. (The values in my example are fake)
I know my english is not very good, but I hope you understand what I mean.
peter_f
ParticipantThanks for that information. I got the current version but sadly I haven’t seen that there is a checkbox to solve just that problem.
