access to Rapid Scada without User/Password
Forum Home › Forums › Uncategorized Issues › access to Rapid Scada without User/Password
  • #2775
    peter_f
    I want to allow user to sccess exact one dashboard by clicking a link. You used this here in the forum to show a user somthing about Dashboards (item 2458). I tried to use this as an example but I don’t understand the systematik. I think that there should be a user with defined permissions. So it should be possible to give the link the nessesary credentials.
    #2781
    If you place *.xml that defines a dashboard into a folder of a particular user, the dashboard will be available for this user only.
    For example, move DashboardExample1.xml
    from C:\SCADA\ScadaWeb\storage\allusers\Dashboard
    to C:\SCADA\ScadaWeb\storage\guest\Dashboard
    #2782
    A user must have permissions to the views that are used in the dashboard.
    #2783
    peter_f
    maybe I described my question not exact. The question is, how can I provide access to a dashboard or to a table without neding a password. My idea was that there should be a way to start rapid scada and write username and password with the page view. ( i.e. ???/scada -user:guest -password:12345) You did that in your example in #2458.
    #2786
    You need a little plugin that performs login and then redirects to another page.
    #2787
    I can’t open #2458 without a hyperlink. Could you provide it?
    #2790
    peter_f
    Hi Mikhail,
    This is the topic I refered.
    If I open a dashboard http://demo.rapidscada.net/plugins/Dashboard/Dashboard.aspx?key=allusers-DashboardDemo using Chrome on Android 5, export to PDF works.
    Wenn I klick the Link rapid scada opens with the dashboard “DashboardDemo” without need to fill in a password. Exact that is what I want do do. Rapid scada should be part of a Webpage where some informations are providet. User should see the Dashboard without need to logon.
    #2792
    peter_f
    This is because you already logged in. If you logout, you can’t open this page.
    So “you need a little plugin that performs login and then redirects to another page.”
    I can help you with it. The most quick way is commercial ))
