April 20, 2021 at 3:59 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8803
hethongscada62
ParticipantDear Mr.Mikhail,
I did not understand. The Rapid SCADA 5.8.2 was installed. It is running now. The Chart Plugin and Chart Pro Plugin are working but they can not process charts. The screen of computer is white.
https://ibb.co/YB8BtZc
https://ibb.co/QvRMSs0
https://ibb.co/yhHBKNw
https://ibb.co/v3mSttr
Why????????????????????????
Thanks so muchApril 20, 2021 at 1:24 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8802hethongscada62
Thank you for your reply.
I think the most sample way to choose the version of Chart Pro will be suitable to Rapid Scada 5.8.0 version. So could you let me know Which version of Chart Pro will be suitable to Rapid Scada 5.8.0? Pls send to me this package of that Chart Pro Plugin.
Thanks a lotApril 19, 2021 at 4:02 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8798hethongscada62
ParticipantAnd the screenshot is bellowing:
https://ibb.co/7KDvJzd
ThanksApril 19, 2021 at 3:51 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8797hethongscada62
ParticipantDear mr.Mikhail
I have done following steps:
1) The scada_5.8.0_ful_en installed on Windows.
2) The scada_5.8.0_mono_en installed in Pi4
3) All plugins were configured on Windows. They are running well then Upload them to Pi4. All plugins in Pi4 are running perfectly except Chart Pro plugin.
Thank you so much
From Han HoangApril 19, 2021 at 3:33 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8796hethongscada62
Chart Pro: Version 5.1.0.1
Webstation: Version 5.8.0
ThanksApril 19, 2021 at 11:48 am in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8790hethongscada62
After editing without saving, the result is the same. There is on the screen of computer:” Application Error
Details:
Method not found: !!0 Scada.Web.WebUtils.GetParamAsEnum<!0>(System.Collections.Specialized.NameValueCollection,string,!!0)”
The scadaWeb.log file is bellowing:
https://ibb.co/xLwBHcd
ThanksApril 19, 2021 at 1:07 am in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8779hethongscada62
ParticipantDear manjey73,
Show access rights to all folders, starting with /opt ?
You can see a screenshot.
https://ibb.co/KjQnrRK
ThanksApril 18, 2021 at 2:28 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8775hethongscada62
The path have been changed. My project Scada installed by default. The path is /opt/scada/ScadaWeb/Config
https://ibb.co/Y8Hxxgv
The result was the same: “Error saving web application settings: Access to the path is denied.”
Why????April 18, 2021 at 1:24 am in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8773hethongscada62
The chmod command have been added. You can see a screenshot bellow:
https://ibb.co/QDMkynx
It is wright, ins’t?
Thanks agianApril 17, 2021 at 1:42 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8769hethongscada62
The issue with re-installation Rapid SCADA in Raspberry Pi have been resolved. All registration keys are working perfectly except Chart Pro key too, can not process the charts. Can not save the configuration on Web. But the Chart is processing charts normally. This issue of Chart Pro Plugin is the same with the person on Russia Forum Rapid Scada.
Pls let us know why?
Thanks a lot
From Han HoangApril 17, 2021 at 4:24 am in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8767hethongscada62
I can not get the result. So i decided to reinstall, but i have had a problem with re-installation.
Can i ask you a question?. Will the registration keys be valid if i re-install OS on the same Raspberry Pi4?
Thanks a lot
From Han HoangApril 16, 2021 at 2:41 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8765hethongscada62
The WebSettings.xml had been edited manually, but the result is the same.
I decided to uninstall and reinstall Rapid SCADA. After reinstallation all registration keys are working normally except Chart Pro key. Can not save a configuration on the Web. Always appears the notice” Error saving web application settings: Access to the path is denied.”
https://ibb.co/m0PqQM5
Very strange!!!
ThanksApril 15, 2021 at 1:43 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8763hethongscada62
ParticipantDear namjey73,
It did not work. Strange. When i replaced access rights of Chart Pro by access rights of Chart, the project is running normally. It processes the Charts for me.
https://ibb.co/X5ppGS4
Maybe are somethings wrong in the Chart Pro file?
I don’t understand.
ThanksApril 15, 2021 at 11:43 am in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8761hethongscada62
The PuTTY was using. It is working, but operation not permitted.
https://ibb.co/L5P5QLC
Why????
ThanksApril 15, 2021 at 10:38 am in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8756hethongscada62
Yes, i connected to Raspberry Pi4 via SSH.
https://ibb.co/VtdrQbP
The specified command was entered likes this:
https://ibb.co/TLNdm0P
It did not work, namjey73
Where is wrong?
Thanks a lot -
