Tom-NTUA
ParticipantAlso, i succesfully followed the instructions for installing the raspberry binaries but i cannot find a way to initialize a GUI, no entry is added to raspberry application menu and inside /etc/scada there is nothing to implicate a GUI launcher. Any help would be highly appreciated.
Thank you
Tom-NTUA
ParticipantWhat we will try to achieve is using the raspberry both as a MCU for the data that we collect (energy and environmental parameters metering) from an ADC chip and also as a client. That is, the end-user will be able to just connect the raspberry to a screen and be able to see the data collected in a graphic way and also use the data from the databases for a later use.
So we would like the raspberry to be able to collect the data via modbus and then use the SCADA to store them in databases. Also via its web , or any other interface, to present them to the end user.
Tom-NTUA
ParticipantMy knowledge of web hosting or online applications is very limited, so i cannot fully understand your answer without some homework,sorry for this!!
So just to make it clear, till Scada-Web is ported to Raspberry, is there an easy way for us to have some graphic representation of the data collected via Modbus?
This reply was modified 11 years, 5 months ago by
Tom-NTUA.
Tom-NTUA
ParticipantTaking into account that we want both server and client side to be implemented on the Raspberryb Pi
Tom-NTUA
ParticipantAs i can see from your first post , you mention that server side is implemented but client side is still to be worked out for a future release. Without client side implementation how data can be visualised for the end user?
Thanks and congrats on your hard work!!
Tom-NTUA
ParticipantGood evening,
We are engaging on a project at National Technical University of Athens concerning a low cost, open source DAQ system. For the purposes of this project we chose the raspberry pi 2 platform , using modbus TCP for data communication and currently we try to choose the best open source SCADA software to use to our project to acquire data, visualize and and store them in an appealing and efficient way.
The raspberry will be used both as data server and as client.
So we would like to know if we could use the rapid scada software on the raspberry pi 2 platform and what problems we may encounter.
Thank you in advance!
