zhaochengshen
Participanthi Mikhail:
I have a issue when i use ModDBExport module to export data.Only events data can be export. the current data and archive data can’t export. I have create table “cnldata” and “events”. Why does it happen? How can solve it?here is the detailed log:
ModDBExport.txt
Export Data Module
State: normalData Sources
1. MSSQL – (local); state: normal; in queue cur/arc/ev: 100/0/0; exported cur/arc/ev: 0/0/24; skipped cur/arc/ev: 150/0/0ModDBExport.log
2017-10-08 00:55:13 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:18 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:23 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:28 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:29 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:33 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:38 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:43 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:48 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:53 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:58 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:03 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:08 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:13 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:18 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:23 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:28 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:29 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:33 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:38 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:43 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:48 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:53 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:56 Module ModDBExport is stopped
2017-10-08 00:56:56 Start ModDBExport module
2017-10-08 01:04:38 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:04:43 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:04:48 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:04:53 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:04:58 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:05:03 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:05:08 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:05:13 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:05:18 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:05:23 Unable to enqueue current data. The maximum size of the queue 100 is exceededzhaochengshen
Participantthanks a lot.I’ll try again.
zhaochengshen
Thanks for you help.
Now it’t connected. There was a problems with the start address set error previous. The start address of Rapid SCADA is 1. -
