devices template Elements count && data conversion
Forum Home › Forums › Communicating with Devices › Modbus › devices template Elements count && data conversion
  • #2499
    zhaochengshen
    I have to two problems.
    1.the maxinum number of elements is 125 in the Device template.
    What should I do if I have more than 125 elements
    2.Is an element a word(2bytes)?
    how can I get the original Hex data?
    now I need convert 2 words to float number or convert 4 words to double number.
    and sometime I need to convert high and low bytes or convert byte location.
    #2500
    1. 125 elements in one group of holding registers. Just add new group.
    2. By default 1 element is a word. You can choose the appropriate type of element in the template for float or double.
    #2502
    zhaochengshen
    thanks a lot.I’ll try again.
