manraj
ParticipantI am flexible with any API system whether its FAT or NTFS. Which do you recommend.. I am new to this.
manraj
ParticipantHi there,
I would want to ask if there is any other cloud systems which is open source that RAPID SCADA can access to.Perhaps a suggestion on a few cloud monitoring sites that I can look into.Is there a way where arduino board can send data to a cloud server and use RAPID SCADA to monitor it?.
manraj
ParticipantHi
I would want to purchase the RAPID SCADA services.But before that I would want to how would you connect to the modbus.Do I require a server room or only just WIFI?.Do I need to configure any settings.
manraj
ParticipantCan this support Modbus because it is integrated with TCP.Does that means it can support Modbus.
manraj
ParticipantHi there!
I am building a pipeline project using RAPID SCADA.I would need to connect some pressure sensors to an arduino and the arduino would need to be connected to the SCADA cloud monitoring.Could you suggest me the typical arduino board and its sensors that is compatible to RAPID SCADA.
manraj
ParticipantFirst value 1000 and the second value is 2000 and third value is 3000
manraj
ParticipantSo if I would the first input channel is 1000 And the next would be 2000.Will this algorithm work? And how will the next value be inserted because in the formula it does not take the second input value.
manraj
ParticipantIf you mean to create a formula that changes the input channel every 5 second then yes.I would need some help in it. Thank you
manraj
ParticipantYup
manraj
ParticipantThe setting of the module https://drive.google.com/drive/folders/0ByrSCDsFCOLYMGlnSW5jV0VGb2s
Basically I would want to insert a value in each input channel through the Automatic Control module every 5 second and I have about 100 differnt values.How do i do it?
manraj
ParticipantHi there.
I have a problem installing the Automatic Control Module(trial), yes I havent not make any payment but I would like to try the trial version first.I have installed it from here http://rapidscada.org/download-all-files/download-automatic-control-module/
I have completed the steps form this http://doc.rapidscada.net/content/en/installation-and-run/module-installation.html#modules
However I could not complete the steps for this part http://doc.rapidscada.net/content/en/modules/mod-auto-control.html
I tried to click the properties on the SCADA server application in the module page but it gives me this error https://drive.google.com/drive/folders/0ByrSCDsFCOLYMGlnSW5jV0VGb2sI installed the Automatic Control Module to insert a few hundred set of values automatically.Is that possible?
manraj
ParticipantI have solve it already thanks.
manraj
ParticipantSo how do i use solve simultaneous equation using Scada. Is there like a source code that i can use or anything?
manraj
ParticipantCan the notification send by the Automatic Control Module via email?.
manraj
ParticipantSo does this mean I only can put a calculated values in the conditions of the dynamic pictures and not the formula itself.
