manjey73Participantin version 6, you don’t need to write /scada
or just localhost or specifying the default port 10008
manjey73ParticipantDo I set up autologin in the SacadWeb instance settings?
manjey73ParticipantBy default, the table takes data from a minute archive, perhaps choosing an archive will help in this case.
You also need to set up Graph calls for this archive.
This reply was modified 1 year, 9 months ago by
manjey73.
January 7, 2025 at 8:54 am in reply to: How to know the network connection status of a device #15929
manjey73ParticipantSorry – For the Divice – service Tag code – Status
January 7, 2025 at 6:28 am in reply to: How to know the network connection status of a device #15926
manjey73ParticipantFor the user, this is the service code of the tag – Status
Create a channel with this tag code.Where the value 0 = Normal, 1 = Error
There is no equivalent for Communication Lines in the current version yet, if I’m not mistaken.
manjey73ParticipantJust create your own formula in the script table, in which you can initialize any variables.
I was doing something similar to version 5 to simulate non-volatile variables through files.
In a simple version, it looks like thisbool initVal = false; public double InitValues() { if (!initVal) { SetData(1153, 0, 1); SetData(1154, 0, 1); SetData(1155, 0, 1); SetVal(1031, 0); SetVal(1032, 1); initVal = true; } return Convert.ToDouble(initVal); }And most importantly, place the channel with the call of this formula at the very first in the channel database.
Moreover, the formulas in the channels themselves can be any.
manjey73ParticipantI checked, there are no errors during compilation, but it seems to me that you are trying to use an internal formula even before the server starts processing formula data. Most likely InitScripts is intended for other things.
manjey73ParticipantIf you look at CalcEngine.cs, then InitScripts() goes first and only then SetData.
When the server is started, this code is compiled every time.
Using SetData inside Initscripts, do you encounter any errors?
manjey73ParticipantPerhaps InitScripts() is intended for other things. And at this point, formulas like setData may not be valid yet.
manjey73ParticipantExplain for which types of channels do you want to set the values to 0 when the server starts?
Show the settings of these channels
manjey73ParticipantCommas are most likely a number separator display format related to the OS regional settings.
manjey73ParticipantIf this is the input channel from the device, you need to use
Cnl/10Cnl, CnlVal double Channel value transmitted to Server before the calculation
manjey73ParticipantI may be wrong, but it seems enough to specify
Val()in the input formula andSetVal(CnlNum, Cmd)in the output, and when the Server starts, the channel will be 0.0, and after entering your valueFor Calculated/Output channels
manjey73.
manjey73Participant// Set the default setpoint value. // For channels of the Calculated/output type public CnlData GetDefaultData(double val) { return Stat() > 0 ? Data() : NewData(val, 1); } // For a channel with the Integer data type public CnlData GetDefaultDataInt(long val) { return Stat() > 0 ? Data() : NewData(BitConverter.Int64BitsToDouble(val), 1); }If I understood correctly, you want to initialize some variables.
Here are the formulas that Mikhail once proposed.Formulas are used in the Input.
GetDefaultData(1)
SetVal(CnlNum, Cmd)is used for the output formulas-
manjey73.
manjey73Participanttranslation of the readme for the module
Extension for launching external applications from RapidScada v.6.2.1.1
ModAbcLogicConfig.xml – a file for configuring the extension.
– AppObject – Settings for launching the application (each application has its own settings).
– – Input Channel – The channel number in Scada. The extension reads the value in the channel (it should be 0 or 1), 0 – does nothing, 1 -launches the application. -
