Viewing 15 posts - 211 through 225 (of 981 total)
  • in reply to: Where should I start looking at the code? #16605
    I would wait for the release of a new editor, if it is related to it. Well, or studied PlgMain.
    in reply to: Send Commond #16595
    Logic Module Development
    You can write your own control module if you are not satisfied with the Automatic Control Module from RapidScada.
    Yes, the Automatic Control Module has limitations, especially if you need to control many different parameters. You can get around this by using scripts, creating one channel that will then control the module, but it’s not always that simple.
    in reply to: Alignment of web controls in V6 #16594
    Static text is not intended for giving commands, it is just some kind of text.
    For control, you must use dynamic text or dynamic drawing. But you can only send one command through them.
    in reply to: Alignment of web controls in V6 #16591
    The question is not entirely clear
    What do you mean by multiple controls?
    in reply to: Send Commond #16586
    No, scripts don’t have access to send commands to devices. This can only be done by modules. For example, an automatic control module or your own.
    in reply to: rapidgate #16579
    Rapid SCADA backup strategy.pdf
    For the Enterprise version, there is a backup module that somehow manages the RapiGate module in this case.
    Ask for a description of this module to understand the process.
    If you have two free versions, then you need to think about how to organize it, it is quite possible that you can somehow do a similar control using, for example, an automatic Control Module
    in reply to: Reading event log from modbus device #16570
    Yes, Mikhail wrote that you can use the driver as a dependency and write something of your own.
    You will have to work with Slice from your part of the new driver. To record data in the channels’ past.
    • This reply was modified 1 year, 3 months ago by manjey73.
    in reply to: Reading event log from modbus device #16568
    The question is, what is this event, and how many are there?
    And I take it they have a past tense? then it’s writing a driver that decomposes these events in the database exactly by time.
    Similar to how the driver works with archives. Modbus cannot work with device archives.
    You can save them only to the current data.
    in reply to: Reading event log from modbus device #16566
    If the registers go sequentially, you can form the command in binary form, for example, an array of bytes. And send it to the device using multiple recordings. In the template, you can additionally create the necessary commands, separate from reading the registers.
    The bigger question here is that reading the main registers is current data, and you may need data from the archive, which is data from the past.
    in reply to: Time string format and Locale #16556
    It’s not exactly rigid, there are default options for a short date for different languages, but you can apply your own format and output it as a string.
    https://learn.microsoft.com/en-us/dotnet/standard/base-types/custom-date-and-time-format-strings
    You can also create your own short format.
    in reply to: Time string format and Locale #16548
    In theory, it can be displayed on a diagram or table in a string format as you like through the Calculated channel using scripts.
    Without touching the dll assembly. The channel cell stores a double representation of the time DateTime.ToOADate(). How you convert it to a DateTime and then to a string doesn’t matter.
    in reply to: Loss Modbus Slave Driver’s computer code #16512
    Apparently, it is necessary for the driver to start, that is, to make the minimum settings for its operation. If the driver is not running, for example, there is no configuration, then the PC code will not be created. See what the driver writes in the logs.
    This applies to all drivers, plug-ins, and modules.
    in reply to: I want to display text from decimal numbers. #16504
    In the channel format properties, select D
    in reply to: about mod develop #16495
    It seems that the fact that the Server sends a command does not guarantee that the device executes the command. For example, an erroneous value that the device will not accept.
    It is necessary to wait for feedback from the device driver.
    in reply to: information of the Archive #16489
    You need to replace the used dll files from the current version of Scada in the utilities
