Joao
ParticipantFor me its better the boolean input keep the old value…
This reply was modified 9 years, 1 month ago by
Joao.
Joao
ParticipantIt works, but the boolean value become “—” too.
The Automatic Control Module read it as 0? I will have problems if I have a trigger with the condition val=0?
Or I have to change the status condition too?-
Joao.
Joao
ParticipantJust take the local ip of your PC server and put on a browser with /scada on final.
ex: 192.168.0.x/scadaJoao
ParticipantIm sorry, I didnt saw this command. My bad.
Thanks Mikhail!
Joao
ParticipantSomething like {CnlVal(xxxx)}
Joao
ParticipantI have cases that the alarm involves two or more variables on his logic. So it turn on or off a boolean variable If attends the alarm condition. I put this boolean variable channel number in Automatic Control configuration, and if I use the command {CnlVal} it will return the boolean value.
Have something that I can do to show on e-mail the variables that make the logic?-
This reply was modified 9 years, 2 months ago by
Joao.
Joao
ParticipantHi all again,
How I send a email with the atual tag value?
Joao
ParticipantHow can I make this formula?
Joao
ParticipantWorks, Thanks!
Joao
ParticipantIf I open it as adm it works, but when i changed the role to Test said “The requested view does not exist or you have insufficient rights to access it.” again.
