January 30, 2017 at 5:08 pm in reply to: Raspberry Pi config: Metadata file `System.dll' could not be found #1913
dsjstc
ParticipantLocalization is default. I’ve got mono 3.10, the latest available on Debian Jessie. Looking through the forum it looks like you tested on 3.28 — Are you on Raspbian? Or did you use an external repository?
$ mono --version Mono JIT compiler version 3.10.0 (mono-3.10.0-branch/ce003f4 Tue Nov 25 20:18:29 UTC 2014) Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com TLS: __thread SIGSEGV: normal Notifications: epoll Architecture: armel,vfp+hard Disabled: none Misc: softdebug LLVM: supporteddsjstc
ParticipantJanuary 27, 2017 at 5:54 pm in reply to: Chartpro request: Separate rows for discrete / binary inputs, etc #1904dsjstc
ParticipantHere’s the only one I have easy access to at the moment.
It’s slightly different from the other system that I described. The legend is by line-colour instead of beside the binary inputs (which I think is a little harder to read), and it uses an up-down line instead of a solid-hollow bar (which is a matter of preference, both work equally well to my mind).
dsjstc
ParticipantThat makes sense. I had expected it to infer that information from the poll frequency in the Communicator settings. In my case, the input is Modbus TCP with a delay of 200 (presumably ms), so the 60s chart data period didn’t seem to be related to anything — I assumed it was a glitch in the chart plugin.
Anyhow, all better now. Thanks for your very helpful response. I’m sure this post will help the next person with this problem!
dsjstc
ParticipantThanks Mikhail. Problem solved. Chart Gap was 30 sec, and I don’t recall ever having changed it.
The effect of this parameter seems counterintuitive. No change if I decrease it, just dots every minute. At 60 seconds, it interleaves 60-second lines with 60-second gaps. At 120 seconds it creates continuous line-segments.
If that’s not expected behaviour, please let me know if I can help isolate it further.
