Passat
  • in reply to: SNMP #1872
    Passat
    Mike i’m highly interested in this implementation. I’m going to contact you personally to resolve this issue.
    in reply to: SNMP #1864
    Passat
    Thanks it worked however you have to know beforehand the strings that the device is giving you. In case, somebody wants to change the name of a particular device and get it back on display, cannot be implemented.
    in reply to: SNMP #1855
    Passat
    Hi Mike, thanks a lot for your explanation. I would like to know how to configure my strings in the enumeration.
    in reply to: SNMP #1852
    Passat
    Hi, is there a way to pass OctetString to ScadaServer?? I have some string values i need to display in the web application.
    If it is not possible, then how can i bypass the scadaserver and show it in the web application? thanks
