SergeyLeb
  • in reply to: Mobile client and Rapid SCADA #2092
    SergeyLeb
    Thank you so much! I will try.
    in reply to: Mobile client and Rapid SCADA #2080
    SergeyLeb
    Sounds good! But, how I can lunch a SCADA application on a mobile device under Android? I must repeat – the main controller is running on PC. What steps I must to do for seeing the information?
    in reply to: Mobile client and Rapid SCADA #2078
    SergeyLeb
    The main application is started on the PC. The PC works as master for Modbus network. Some time I need to connect to the application (for seeing the process status) via mobile (Android or IOS) application. So, I understand, I must to use an OPS server which delivers information for the Rapid SCADA application and something “WEB server”. Am I right?
    in reply to: Polling cycle time #1925
    SergeyLeb
    Thank you! I will read through.
    in reply to: Polling cycle time #1919
    SergeyLeb
    It are connected to Owen’s TRM 136 module. The module connects to a web communication module via RS486 interface. The connection goes through a TCP server and reaches my workstation. Of case, I understand that there could be timeouts in the TCP server.
    But, how can I adjust the pulling cycle IN RAPID SCADA SOFTWARE: in the Rapid Communicator or Rapid Server or Rapid WEB interface?
    in reply to: Polling cycle time #1917
    SergeyLeb
    There is a local panel with the value indication. I able to change income parameter (temperature) and watch the value on display (“hardware”) and on the SCADA. Time between changing the values is about 30-40 sec.
    But it is question not about faster the system. The question is about how can I adjust the pulling time: for temperature it could be bigger than for pressure.
    in reply to: Access SCADA-web configurator #1765
    SergeyLeb
    Hi, You should go to Interface in the SCADA Administrator and add there your items. The table or pictures must be in directory X:\SCADA\Interface\your system.
    in reply to: Access SCADA-web configurator #1702
    SergeyLeb
    Sorry for the disturbance. I found how it could be made.
    in reply to: Access SCADA-web configurator #1701
    SergeyLeb
    Sorry, but I can’t find how I can add my views. What the Internet browser could be used?
