Setsero
Viewing 1 post (of 1 total)
  • in reply to: I need to read data format RTU modbus INT32-M10K #1661
    Setsero
    thanks for your quick response.
    the algorithm for obtaining data INT32-M10K
    is:
    Example (Signed):
    Value ‐12345678 is passed in signed 32‐bit Modulus‐10000 format. Both high and
    low are signed.
     Registerhigh: ‐1234 = FB2E Hex
     Registerlow: ‐5678 = E9D2 Hex
     Value = ‐1234 x 10000 + ‐5678 = ‐12345678
    Modbus register map
    Label—–Address—-Number of register—-Format
    kWh del—-40089————2————-INT32-M10K
    I divided into two registers so
    Label———-Address—-Number of register——–Format
    kWh del high—-40089————1————–short (2 bytes)
    kWh del low—–40090————1————–short (2 bytes)
    SCADA-Administrator, Formulas table
    kWh del high Cnl*10000
    kWh del Val(n)+Val()
    (n) is the number of impout channel kWh del low
    • This reply was modified 10 years, 1 month ago by Setsero.
