Viewing 1 post (of 1 total)
sarinda
Can you please tell me a Modbus library for Arduino which is compatible with RapidScada. I am having troubles with communicating with an arduino.I tried following code. It works with QMB (for modbus checking) but no data is received by rapidScada.
#include <modbus.h> #include <modbusDevice.h> #include <modbusRegBank.h> #include <modbusSlave.h> /* PINS Add more registers if needed Digital input pins 2,3,4,5,6,7 Digital output pins 8,9,12,13 Analog output pins 10,11 (PWM) Analog input pins 0,1,2,3,4,5 */ modbusDevice regBank; modbusSlave slave; int AI0,AI1,AI2,AI3,AI4,AI5; void setup() { regBank.setId(1); ///Set Slave ID //Add Digital Input registers regBank.add(10002); regBank.add(10003); regBank.add(10004); regBank.add(10005); regBank.add(10006); regBank.add(10007); // Add Digital Output registers regBank.add(8); regBank.add(9); regBank.add(12); regBank.add(13); //Analog input registers regBank.add(30001); regBank.add(30002); regBank.add(30003); regBank.add(30004); regBank.add(30005); regBank.add(30006); //Analog Output registers regBank.add(40010); regBank.add(40011); slave._device = ®Bank; slave.setBaud(9600); pinMode(2,INPUT); pinMode(3,INPUT); pinMode(4,INPUT); pinMode(5,INPUT); pinMode(6,INPUT); pinMode(7,INPUT); pinMode(8,OUTPUT); pinMode(9,OUTPUT); pinMode(12,OUTPUT); pinMode(13,OUTPUT); } void loop(){ while(1){ //Digital Input byte DI2 = digitalRead(2); if (DI2 >= 1)regBank.set(10002,1); if (DI2 <= 0)regBank.set(10002,0); byte DI3 = digitalRead(3); if (DI3 >= 1)regBank.set(10003,1); if (DI3 <= 0)regBank.set(10003,0); byte DI4 = digitalRead(4); if (DI4 >= 1)regBank.set(10004,1); if (DI4 <= 0)regBank.set(10004,0); byte DI5 = digitalRead(5); if (DI5 >= 1)regBank.set(10005,1); if (DI5 <= 0)regBank.set(10005,0); byte DI6 = digitalRead(6); if (DI6 >= 1)regBank.set(10006,1); if (DI6 <= 0)regBank.set(10006,0); byte DI7 = digitalRead(7); if (DI7 >= 1)regBank.set(10007,1); if (DI7 <= 0)regBank.set(10007,0); //Digital output int DO8 = regBank.get(8); if (DO8 <= 0 && digitalRead(8) == HIGH)digitalWrite(8,LOW); if (DO8 >= 1 && digitalRead(8) == LOW)digitalWrite(8,HIGH); int DO9 = regBank.get(9); if (DO9 <= 0 && digitalRead(9) == HIGH)digitalWrite(9,LOW); if (DO9 >= 1 && digitalRead(9) == LOW)digitalWrite(9,HIGH); int DO12 = regBank.get(12); if (DO12 <= 0 && digitalRead(12) == HIGH)digitalWrite(12,LOW); if (DO12 >= 1 && digitalRead(12) == LOW)digitalWrite(12,HIGH); int DO13 = regBank.get(13); if (DO13 <= 0 && digitalRead(13) == HIGH)digitalWrite(13,LOW); if (DO13 >= 1 && digitalRead(13) == LOW)digitalWrite(13,HIGH); //Analog input ***READ Twice deliberately AI0 = analogRead(0); delay(10); AI0 = analogRead(0); regBank.set(30001, (word) AI0); delay(10); AI1 = analogRead(1); delay(10); AI1 = analogRead(1); regBank.set(30002, (word) AI1); delay(10); AI2 = analogRead(2); delay(10); AI2 = analogRead(2); regBank.set(30003, (word) AI2); delay(10); AI3 = analogRead(3); delay(10); AI3 = analogRead(3); regBank.set(30004, (word) AI3); delay(10); AI4 = analogRead(4); delay(10); AI4 = analogRead(4); regBank.set(30005, (word) AI4); delay(10); AI5 = analogRead(5); delay(10); AI5 = analogRead(5); regBank.set(30006, (word) AI5); delay(10); //Analog output word AO10 = regBank.get(40010); analogWrite(10,AO10); delay(10); word AO11 = regBank.get(40011); analogWrite(11,AO11); delay(10); slave.run(); } } -
