trauden
ParticipantI use the formula DateTime.Now and set in the format as Time and Day but it returns only the value: 10/01/1900 00:00:00. It not changes and not the same as the time system.
BRstrauden
ParticipantYes. The latest event is alway on the top of the table.
trauden
ParticipantI got it. I found out the error.
Thansk all. Mikhail and Manjey73.trauden
ParticipantThank so much Mikhail.
trauden
ParticipantI’ve writen a formula
double SPFloat()
if(Cnl==0) return 10.5;
if(Cnl==1) return 50.0
if(Cnl==2) return 101.5
it’s correct.trauden
ParticipantI also tested with the simple formulas ( Cnl*100) but the commands returned only 0.00. Without formula results are 0.00 1.00 and 2.00. I dont know data type of the results. Is int or real or string?
trauden
ParticipantThanks Mikhail,
trauden
I tried to change passwords for login to web. But it failed.
It possible to change passwords in website? Mikhail.trauden
ParticipantFor example: I can get data from tag having parameter: Input channel: 101; Name: OPCSimChannel1; Channel Type: Real; Object: Enterp rise; Device: OPCDemo; Signal:1;
for external purpose (display in JustGage ((http://justgage.com/).).
I can do it?
Please help me Mikhail!trauden
ParticipantThanks Mikhail.
trauden
ParticipantI mean that put a link in the Main Scheme and click on this link to open a new tab of the browser.
trauden
ParticipantThanks a lot. Mikhail.
I got it.trauden
ParticipantI have created Object as Dynamic Text. But I couldn’t know how to configure in Action and Input/output properties. Could you explain more details, please?
