Praveen
Thank you for the information :-).
I am able to send commands now.
With B/R,
Praveen.BPraveen
In commands tab of communicator, I could see only entry for password (Not sure what password it is.)
Screenshot is at: https://postimg.org/image/xec0xteb5/
Can you please let me now if I am missing anything and give more details on modbus commands.
Praveen
There was connection issue to my DB.
Problem is solved.
With B/R,
Praveen.BPraveen
If I want to purchase a module, what will be the approximate cost?
With B/R,
Praveen.BPraveen
I need to read data for every 30 minutes and want to write it to file.
So I am interested only last 30 minutes data, whenever I try to read.And also I want automate this process.
Is there any good way of doing this?
Praveen
How to write values to MySQL? Is there any direct way?
(or) do we need to write application to read from dat files and write to MYSQL?
With B/R,
Praveen.BPraveen
Thank you for the answer.And the issue is solved.I could connect to 2 modbus simulators on different ports.
With B/R,
Praveen.BPraveen
ParticipantHi, sorry for the inconvenience..
Not able to keep the image, editor is accepting only the text.
where can I keep the screenshot?In communicator, I imported communication line and selected modbus communicator
type as modbus TCP.then, Port is selected by default as 502, and not allowing to change to any other port.
Praveen
ParticipantYes. In that case RapidScada also should listen at port 503 right?
Can you help me in changing TCP port to 503 in client?
(if I select Modbus TCP, by default RapidSCADA takes 502 port and not editable)
With B/R,
Praveen.BJune 24, 2016 at 4:23 am in reply to: While importing communication line, device is not getting imported. #1325Praveen
ParticipantSorry, the issue is solved. After giving device template, it works fine.
With B/R,
Praveen.BPraveen
Please find modbus communication log for the one which I am not able to connect.
2016-06-24 08:52:07 Unable to communicate with the device because connection is not established
2016-06-24 08:52:37 Unable to communicate with the device because connection is not established
Same slave I could connect from server room. Communication log is:Request element group “Max. Temperature”
Send (12): 00 00 00 00 00 06 00 03 00 0A 00 07
Receive (7/7): 00 00 00 00 00 11 00
Receive (16/16): 03 0E 0C 76 0C 76 0C 76 0C 76 0C 76 0C 76 0C 76——————————————————————————–
I have one more question.
How to change the Modbus TCP default port? Suppose I want to run 2 slave simulators from same machine and different ports.
With B/R,
Praveen.BPraveen
ParticipantHi Mikhail,
I am using TCP client and using 502 port only.
And if I connect to slave simulator with “ADAM-6015 Server room”, I am able to read the data. If I configure new Modbus client, I am not able to get the data.
Can you help me in trouble shooting it?
With B/R,
Praveen.B -
