maksimred
ParticipantI like it. When can we beta test?
maksimred
ParticipantI would really like to see the “oshibka servera….” window minimized then when I click on a temperature or some value then the minimized window will expand like u have it in the screenshot and trend graph loads to show the recorded events.
maksimred
ParticipantHi Mikhail, any update to this. it is spring of 2016, and silverlight is still the main driver for the schemes. chrome dropped support for npapi, and firefox is on the road to.
Thanks.
May 16, 2016 at 11:58 pm in reply to: "Application Error: Unable to Load View" Error Windows 10 #1187maksimred
ParticipantMikhail Thx.
You are the man, it worked like a charm. Any reason this is? a bug?
May 15, 2016 at 8:30 pm in reply to: "Application Error: Unable to Load View" Error Windows 10 #1179maksimred
ParticipantHi Mikhail, Thx for your fast reply, see below for the ViewSetings.xml per your request.
<?xml version="1.0" encoding="utf-8"?> <ViewSettings> <ViewSet name="Home Meters" directory=""> <View type="SchemeView" fileName="MainSKPanel.sch">MainSKPanel</View> <View type="TableView" fileName="InputMeterTable.tbl">Meters</View> <View type="TableView" fileName="BCMMeters.tbl">BCMMeters</View> <View type="SchemeView" fileName="ServerRoom.sch">Server room temperature</View> </ViewSet> </ViewSettings>Full path to the .tbl files is
C:\SCADA\Interface\Serversmaksimred
ParticipantNevermind, My mistake for not creating the channels numbers from the service menu. All works now.
