dhiraj@factorian.io
  • in reply to: OPCUA Server Certificate Period #18575
    dhiraj@factorian.io
    Still same, I have deleted both the files(DrvOpcUa.View.xml & DrvOpcUa.Logic.xml), stopped and restarted from services all Rapid services, deleted the old certificate but again got 1 year certificate.
    How should i solve this?
    I am not able to find the Certificate generation script also, if i can change manually in that
    in reply to: OPCUA Server Certificate Period #18564
    dhiraj@factorian.io
    Yes, The certificate was created by old version, which i had deleted, but then also it created for 1 year only.
    What i did:
    1. Update the Rapid Scada to latest version
    2. delete the certificate
    3. restarted/update again
    4. Still got 1 year certificate
    Can i create custom expiry time certificate? If no what is the solution
    in reply to: OPCUA Server Certificate Period #18562
    dhiraj@factorian.io
    Hi Mikhail,
    I am using 6.1.2.0 version of DrvOpcUA and i checked the Certificate period from folder in ” \ProgramData\OPC Foundation\pki\own\certs ” and also from UA browser where in it says my certificate is expired.
    Let me know
