pang43351
  • pang43351
    Hi Mikhail,
    Thank you for asking for clarification.
    My goal is to display real-time data from Rapid SCADA directly on our company’s internal web portal. For example, I want to show the status of a machine (like ‘Running’ or ‘Stopped’) and some key performance indicators (KPIs) as a gauge or a chart on our portal’s dashboard page.
    Initially, I tried to use an <iframe> to embed the SCADA Webstation page, but I encountered security errors (Mixed Content and Cross-Origin issues), and you mentioned that SCADA is not designed for this.
    So, my specific question is: What is the recommended method to get live channel data from Rapid SCADA to display on a separate, custom-built website?
    I believe using the SCADA API might be the correct approach. If so, could you please provide me with the following information to get started?
    1. Where can I find the documentation for the API ?
    2. How do I enable or access the API ?
    3. Could you provide a simple example of an API request to get the current value of a specific channel (e.g., channel number 1) ?
    Thank you for your guidance.
    Best Regards,
    Banthoon
    pang43351
    Do you have any other suggestions? I would like to display the Factory Layout in the SCADA system I developed to show the machine status.
