Hi Mikhail
Thanks for the feedback. I realized that I had the channel as Input instead of calculated so once I changed that the formula mentioned above worked.
I am also trying to monitor the data connection health so I’ve put in a channel using the Stat function. I put it in the dashboard but was showing a 13 or 4 depending on connection quality. I added into the forumula to change it to a 1 or 0 and then changed the format to Error/Normal and that working. I am also trying to track if a device freezes. I noticed that one of my devices had readings that were frozen based on the last reading. Is there a way to have a channel for these sensors to flag when the reading freezes for more than 10-15 seconds or something like this? I am also ironing out some polling issues as I’m getting a lot of unreliable events. I think my times are too tight
