Sparkle75
Viewing 15 posts - 16 through 30 (of 30 total)
  • in reply to: Not getting to view as a web page #16273
    Sparkle75
    in reply to: Not getting to view as a web page #16265
    Sparkle75
    They should be public now. Thanks, Tim
    in reply to: Not getting to view as a web page #16262
    Sparkle75
    Log files
    Hopefully this will work.
    The Server log shows that it is working correctly, but I can’t log in and can’t view any tables.
    Thanks!
    Tim
    in reply to: Webstation issues on Win11 #16254
    Sparkle75
    Going to localhost:10008 takes me to localhost:10008/login and the error below.
    Error
    An error occurred while processing your request.
    Request ID: 00-b28aa8b10ece893cc0f863a76b60ab9e-b6f8a75f75278f36-00
    Development Mode
    Swapping to the Development environment displays detailed information about the error that occurred.
    The Development environment shouldn’t be enabled for deployed applications. It can result in displaying sensitive information from exceptions to end users. For local debugging, enable the Development environment by setting the ASPNETCORE_ENVIRONMENT environment variable to Development and restarting the app.
    in reply to: Webstation issues on Win11 #16252
    Sparkle75
    Now i have the WebStation running. I still don’t understand how I can get the data to appear on a web page.
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ACT] Webstation 6.2.0.3 started
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ACT] Storage FileStorage 6.2.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dll
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ERR] Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\ScadaCommon.en-US.xml
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ERR] Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\ScadaWeb.en-US.xml
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgChart 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgMain 6.1.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgScheme 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgSchBasicComp 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgStore 6.1.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgStore.dll
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgWebPage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ERR] Plugin PlgChart: Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\PlgChart.en-US.xml
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ERR] Plugin PlgMain: Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\PlgMain.en-US.xml
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ERR] Plugin PlgScheme: Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\PlgScheme.en-US.xml
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ERR] Plugin PlgStore: Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\PlgStore.en-US.xml
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ERR] Plugin PlgWebPage: Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\PlgWebPage.en-US.xml
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
    2025-03-17 14:50:44 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
    2025-03-17 14:50:46 [QA-TIM-R][QA-TIM-R$][ACT] The configuration database has been received successfully
    2025-03-17 14:50:46 [QA-TIM-R][QA-TIM-R$][INF] The application is ready for operating
    in reply to: Webstation issues on Win11 #16251
    Sparkle75
    Would you be able to explain the process of how the data from the Communication lines is transferred to the WebStation? I think understanding the process would greatly help in troubleshooting.
    Thanks!
    Tim
    in reply to: Webstation issues on Win11 #16250
    Sparkle75
    And under “Instance Status” it has that the Server and Communicator are Normal, but the Webstation is “Status not supported”.
    Not having any success getting the screenshots. Sorry!
    BTW, using Windows 10 Pro
    in reply to: Webstation issues on Win11 #16249
    Sparkle75
    Incorrect format of data received from the server: data length is too big
    2025-03-14 14:38:22 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
    2025-03-14 14:38:22 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
    2025-03-14 14:38:32 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
    2025-03-14 14:38:32 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
    2025-03-14 14:38:42 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
    2025-03-14 14:38:42 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
    2025-03-14 14:38:52 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
    2025-03-14 14:38:52 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
    2025-03-14 14:39:02 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
    2025-03-14 14:39:02 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
    2025-03-14 14:39:12 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
    2025-03-14 14:39:12 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
    2025-03-14 14:39:21 [QA-TIM-R][QA-TIM-R$][ACT] Webstation is stopped
    in reply to: Webstation issues on Win11 #16243
    Sparkle75
    I created a view with a table, but the table does not display any information to the web page. I keep going through the steps in the YouTube video, but nothing. Also, there is no Interface item on the tree.
    in reply to: Web Station Error 500 #16232
    Sparkle75
    Thank you! Back to setting it up again.
    in reply to: Web Station Error 500 #16227
    Sparkle75
    Trying to reinstall and I get this message:
    Website with the same name exists and Application pool item already exists.
    How so I deal with this, please?
    in reply to: Web Station Error 500 #16226
    Sparkle75
    Now I have completely mess things up. How can I totally uninstall the program and servers so that I can install it again?
    Thanks,
    Tim
    in reply to: Web Station Error 500 #16225
    Sparkle75
    Perhaps I should have included this:
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ACT] Webstation 6.2.0.3 started
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ACT] Storage FileStorage 6.2.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dll
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ERR] Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\ScadaCommon.en-US.xml
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ERR] Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\ScadaWeb.en-US.xml
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgChart 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgMain 6.1.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgScheme 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgSchBasicComp 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgStore 6.1.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgStore.dll
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgWebPage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ERR] Plugin PlgChart: Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\PlgChart.en-US.xml
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ERR] Plugin PlgMain: Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\PlgMain.en-US.xml
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ERR] Plugin PlgScheme: Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\PlgScheme.en-US.xml
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ERR] Plugin PlgStore: Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\PlgStore.en-US.xml
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ERR] Plugin PlgWebPage: Dictionary file not found and replaced with default file: C:\Program Files\SCADA\ScadaWeb\lang\PlgWebPage.en-US.xml
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
    2025-03-05 09:51:37 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
    2025-03-05 09:51:40 [QA-TIM-R][QA-TIM-R$][ACT] The configuration database has been received successfully
    2025-03-05 09:51:40 [QA-TIM-R][QA-TIM-R$][INF] The application is ready for operating
    2025-03-05 09:54:21 [QA-TIM-R][QA-TIM-R$][ACT] User admin is logged in, role 1, IP 127.0.0.1
    2025-03-05 09:56:41 [QA-TIM-R][QA-TIM-R$][ACT] Webstation is stopped
    in reply to: Web Station Error 500 #16224
    Sparkle75
    I keep seeing in the log that the Webstation is stopped. Now what?
    Thanks,Tim
    in reply to: Web Station Error 500 #16221
    Sparkle75
    I can see the data updating in the table view, but I always get this error when trying to access the webpage at localhost:10000/login or localhost:10008/login.
    HTTP Error 500.19 – Internal Server Error
    The requested page cannot be accessed because the related configuration data for the page is invalid.
    Detailed Error Information:
    Module IIS Web Core
    Notification Unknown
    Handler Not yet determined
    Error Code 0x8007000d
    Config Error
    Config File \\?\C:\Program Files\SCADA\ScadaWeb\web.config
    Requested URL http://localhost:10008/login
    Physical Path
    Logon Method Not yet determined
    Logon User Not yet determined
    Config Source:
