Viewing 15 posts - 5,821 through 5,835 (of 6,387 total)
  • in reply to: RPi as a TCP server, Local PC as a client #1460
    You should create a new topic on Understanding the Software subforum. There is no RPi specifics.
    in reply to: Window10 #1459
    Install MSSQL Compact from the distributive:
    both
    SSCERuntime_x86-ENU.msi and
    SSCERuntime_x64-ENU.msi
    in reply to: RPi as a TCP server, Local PC as a client #1452
    I want to utilize the Scada Web service, first should I change the server to the ip of the RPi on which the Scada Server is set or should I leave it as it is ?
    If the web app work on another computer than Server, you must set the IP of the server in the web app settings.
    Second: Do I need a specific port number or leave it at 10000 ?
    Do not mix up the port of web server which is 80 by default and the port of Server app which is 10000 by default. You can change both of them, but you should understand that they are the different things.
    in reply to: Incomplete package for Linux (Mono) #1450
    I think it’s more generic to port existing desktop apps to Linux because new modules are created regularly, so creating GUI and web version for every new module requires more LoE. Development of a web form usually takes more time than similar desktop form.
    The idea is allowing new forms works well on Windows and Linux without additional efforts. But is this possible or not requires verification.
    in reply to: Documentation request #1449
    I think that such editor should be open source because the core of Rapid SCADA is open source and the open source model is very powerfull. As usually happens in the open source world the development of the required feature could be sponsored to get it in time.
    Let’s talk about the quick solution: convert DB to SQLite. This work consists of 2 subtasks:
    1. Covert DB itself.
    2. Develop a utility that will “pass the configuration database to server app”. It means convert SQLite to *.dat files used by the Rapid SCADA apps.
    I can send you ER model of DB if you send me email request. It helps you to estimate how difficult to configure the system manually.
    in reply to: Documentation request #1447
    Specialized editor allows to choose values for foreign keys, has utility functions such as input channel generator, clone channels, creating channel map those significantly reduce work.
    in reply to: Incomplete package for Linux (Mono) #1444
    Definitely. The cause is that GUI applications do not work on Linux. As I wrote on GitHub, it is possible to make them work with Mono, but it requires a research.
    The current approach is creating a configuration using Windows then upload it on Linux machine. If there is no access to Windows, the existing apps should be ported to Linux or web.
    in reply to: Documentation request #1442
    In short, the following things allow you to use Rapid SCADA on Linux without Windows:
    – Convert the configuration database to SQLite and develop an editor for it
    – Document all the XML configuration files
    in reply to: Documentation request #1441
    Documentation
    The params aren’t documented in it
    Yes, but it’s easy to guess and try 🙂
    The format is straightforward.
    How about replacing the Microsoft SQL Server Compact (*.sdf) format with more universal one, like for example sqlite (*.db)?
    It is a good and cross-platform alternative. Anyway it’s hard to configure the system by standard DB editor without a specialized GUI editor.
    in reply to: Documentation request #1439
    All the existing GUI apps those are used for system configuring (excluding view editors) will be joined to a one application. It is possible to make this application support Linux with help of Mono framework. The view editors will be ported to web.
    in reply to: Documentation request #1438
    The most problem could be is editing the configuration database in Linux, because it has Microsoft SQL Server Compact (*.sdf) format. This format is used for editing only, not for operating. I don’t know the context of your project and task. If you described it, I could generate an idea how to solve it in optimal way.
    in reply to: Documentation request #1437
    All the existing manuals are published.
    If you edit *.tbl by Table editor, all parameters are accessible via GUI.
    If you edit them manually, see ServerRoom.tbl as an example.
    If something is not clear, ask on this forum.
    in reply to: [Fatal error] Application Exception #1435
    OK. You may ask for advice if needed.
    in reply to: [Fatal error] Application Exception #1432
    Only the part with /scada started to work and the remaining ones still throw errors
    Sorry, I didn’t catch what part works for now?
    The problem is really weird. I think you should surf the linux forums for the clue why XSP doesn’t work. Users use Rapid SCADA on Ubuntu, but this error ocuurs the first time.
    in reply to: [Translation] Assembling ScadaServer 4.5.7 in Mono #1431
    Thanks for the translation!
