Viewing 15 posts - 5,536 through 5,550 (of 6,388 total)
  • in reply to: KpModbus – function code 16 (10 hex) Write multiple #2108
    Function 0x10 already supported. The driver KpModbus.dll uses 0x10 function if you tick Multiple checkbox for a command.
    in reply to: RapidScada for Respberry Pi #2106
    Hi! To be honest, I have no info about RPi emulation. If you run Rapid SCADA on the emulator, please let me know.
    in reply to: Button object #2103
    Just use Dynamic Text element in your scheme. Set its border, back and fore color, and specify appropriate Action and Input/Output channel properties. It will work as button.
    in reply to: Numbers can not be seen in the table. #2101
    Copy the full request URL of GetHourCnlData into browser address bar and make a screenshot of the result.
    in reply to: Numbers can not be seen in the table. #2099
    Yes, do the following:
    1. Open Chrome and press F12
    2. Go to Network tab
    3. Find the requests sent to a web server.
    4. What dates are in the requests? Provide screenshots please.
    I can connect to you remotely and help on commercial basis if you would like. It may be mach faster than forum support.
    in reply to: ModDBExport issue #2097
    You forget a log file. It’s name is lineXXX.log
    in reply to: ModDBExport issue #2095
    Please provide communication line log (C:\SCADA\ScadaComm\Log) and the result of the following SQL request:
    select distinct datetime from cnldata order by datetime desc
    in reply to: RapidScada for Respberry Pi #2093
    In general, yes. You should find out how to run browser in kiosk mode on Raspberry startup.
    in reply to: RapidScada for Respberry Pi #2090
    I recommend Raspberry Pi 3 Model B. Usually, I connect to RPi remotely using Putty and WinSCP to configure it, and don’t need a screen for RPi.
    in reply to: ModDBExport issue #2088
    I agree, it is strange that time stamps are so close to each other. How many polling cycles are performed by Communicator per second? Do they stay close in long time interval?
    We can develop SQL scripts according to your custom requirements on a commercial basis.
    in reply to: ModDBExport issue #2085
    You can decrease polling speed of Communicator by increasing delay after requests.
    Or may be change SQL for export current data to fit your needs.
    • This reply was modified 9 years, 6 months ago by Mikhail.
    in reply to: ModDBExport issue #2084
    SQL script for export archive data is executed very rare, in special cases when a driver of Communicator implements this feature.
    SQL script for current data is executed for each value of input channel (tag) that is sent from Communicator to Server.
    in reply to: Mobile client and Rapid SCADA #2082
    To see the information, open up to date mobile browser and type http://your-address/scada
    Find out in the Internet how to create shortcuts.
    in reply to: Mobile client and Rapid SCADA #2081
    I mean that the web application is properly tested on iOS and Android. It is possible to create a shortcuts on mobile desktop to run the app by one click (tap). Even if web server works on Windows, the web interface is accessible via LAN or Internet using different devices.
    in reply to: Mobile client and Rapid SCADA #2079
    Rapid SCADA contains all the necessary features to implement this. You don’t need OPC server and other 3rd party software.
