Viewing 15 posts - 5,326 through 5,340 (of 6,388 total)
  • in reply to: Chart Pro Y Axis scaling #2720
    Y axis is scaled automatically depending on the range of values.
    Do you want fixed scaling by Y?
    in reply to: Windows 10 Pro (x64) – Unable to access web app ? #2719
    It’s better to restore the default values:
    SCADA-Server uses port 10000.
    IIS web server (the web application) uses port 80.
    I suggest to help you by remote connection for a fee. It will save your time.
    in reply to: Telegram bug #2715
    This is something new.
    Please send me the content of C:\SCADA\ScadaComm\Config to reproduce the bug.
    Also describe the sequence to raise this error.
    • This reply was modified 8 years, 11 months ago by Mikhail.
    in reply to: sankey #2712
    You right to avoid writing email here.
    Please send your vision to email published here.
    in reply to: Windows 10 Pro (x64) – Unable to access web app ? #2710
    Don’t use port 10000 for web application. It works on port 80 by default.
    What is shown by http://localhost/scada/Login.aspx ?
    in reply to: Windows 10 Pro (x64) – Unable to access web app ? #2706
    Features seem OK.
    Try http://localhost/ Does it work?
    Please check, may be the default port 80 is used by another web server?
    in reply to: "," of numbers #2704
    If you set en-US or pt-BR, for example, formatting will be changed but the software loads the existing en-GB files.
    in reply to: Building a tank with a level bar #2702
    1. Create a set of images with different levels by your favorite graphical editor.
    2. Use Dynamic Picture component and define Conditions property to change image according to the current value.
    Note: a control library includes ready to use level control is under development currently.
    in reply to: sankey #2699
    Thank you for the detailed explanation.
    I think the appropriate plugin should be implemented as a custom development. We could discuss the requirements and a price by email.
    Your English is good enough 🙂
    in reply to: Chart Pro Suggestion #2698
    Hi Joao,
    You right. This is a known issue. I want to add an option to remove legend.
    in reply to: "," of numbers #2697
    Formatting depend’s on the culture that is set in Webstation settings and this culture parameters of the server. For example, en-GB.
    in reply to: sankey #2689
    I typed this into Google and got huge amount of different diagrams. Could you provide an example with energies?
    in reply to: Modbus WAGO #2688
    OK 🙂
    in reply to: Modbus WAGO #2682
    In the new version of the Modbus driver you can switch the addressing base: 0 or 1. See Figure 10 of http://doc.rapidscada.net/content/en/use-cases/modbus-protocol.html
    in reply to: Modbus WAGO #2676
    Do you mean the address offset specified for a device or specified for SCADA?
