MikhailModeratorPress F12 in the browser, quickly open the Console tab and make a screenshot.
First of all, you should create a Modbus template in the Communicator application.
If you already create the template, please provide a screenshot. Otherwise, create a template and try to send a command using the UI of Communicator.
MikhailModeratorDisable activations subitems of .Net 3.5.1 node. This is important.
Did you change a password of ScadaComm user in the Administrator app or change user and password in Common parameters of Communicator?
Thanks a lot!
I’ll try the next week and let you know.
MikhailModeratorπ
MikhailModeratorThe screenshot is not accessible.
MikhailModeratorOK π
Do you still want me to send you any data?
I also tried to reproduce the bug. But I can’t. I’m sure the bug exists, but we need to know the magic sequence how to raise it. If you realize this sequence, tell me, please. You don’t need to send me the config now.
MikhailModeratorI sent an email.
Thank you for the link. It’s better than a screenshot.
Try http://fischerp.selfhost.eu:8888/Scada/View.aspx?viewID=2
You will get “The requested view does not exist or you have insufficient rights to access it.”You specified
Widget type=βChartβ cnlNums=β601,602,603,604,605β³ viewIDs=β2,2,2,2,2β³
in the dashboard settings.
But you have to specify the existing view that really contains the channels 601…605
May be viewIDs=β64,64,64,64,64β³
Of course.
What a formula do you plan to use in mathematical manner?
MikhailModeratorHi Peter,
I don’t think that the error relates to a new key. Anyway we need to solve it.
View is a scheme or a table which is specified in the Interface table in Administrator.
What is the URL of the page with the error?
Copy here the errors from the logs of SCADA-Server and Webstation.
Post here a link to a screenshot of the Interface table.
Post here the dashboard configuration, please.
MikhailModeratorThis feature requires modification of the plugin source code. We could discuss the custom development by email.
MikhailModeratorPlease provide a screenshot of your Windows features dialog. I suppose, WCF was not installed.
