You should create an input channel of Calculated Discrete type for each bit and use the formula GetBit for these channels
Example: GetBit(Val(101), 1) – gets 1st bit from channel 101
First of all, remove the existing installation of Rapid SCADA.
Open Windows features list and check the required options needed for the web app, see images at http://doc.rapidscada.net/content/en/installation-and-run/software-installation.html
Login behavior will be improved in the next version of Rapid SCADA. You should try it when the new version will be published.
Change the fore color to “Status”. The color of the component will reflect channel status.
I can help you step by step by providing online training. If you are interested in the training, please contact me by email.Also I can help you on this forum. In this case, I need the specific questions to answer.
MikhailModeratorI can create such formula for you for a fee.
MikhailModeratorYou can try writing command files from a function specified in the configuration database.
MikhailModeratorSome of TPC devices support multiple connections, some not.
It’s possible, but it may be changed in the future versions.
You can create special files to start/stop communication lines in C:\SCADA\ScadaComm\CmdCommand files examples: https://yadi.sk/d/MDH-CrFW3PnjTh
Also see SaveCmd function.
Do you mean fore color of dynamic text component of a scheme?
Formula example for channel 1:
Cnl; Cnl < Val(10) ? 12 : 14 12 and 14 are the existing statuses. If channel 1 has "calculated" type, use Val() instead of Cnl
MikhailModeratorIt’s possible to create an integration module as custom development by a contract.
December 14, 2017 at 11:10 am in reply to: Error: The keyset is not defined in SCADA Administrator #2953
I recommend to switch off automatic backup of the database (in the app settings) and back it up manually by copying C:\SCADA\BaseSDF\ScadaBase.sdfDecember 12, 2017 at 2:15 pm in reply to: Error: The keyset is not defined in SCADA Administrator #2941
This is the first time when such error occurs.
Please watch the details in C:\SCADA\ScadaAdmin\ScadaAdmin.err and copy them here. -
