Viewing 15 posts - 4,816 through 4,830 (of 6,391 total)
  • in reply to: Integration of Charts in Webstation #4067
    Please translate this answer. It may help.
    in reply to: Integration of Charts in Webstation #4065
    You can use Dashboard Plugin
    The demo is here.
    In the future we plan to develop a scheme component to display charts in schemes.
    in reply to: Modbus TCP over GPRS (S27x GPRS RTU) #4062
    Could you configure Communicator based on your intuition, then try the configuration? In case of issues, share screenshots with the settings and communication logs.
    how I have to configure the channel setting type tcp cliente, tcp master, in properties, master, Slave, connection individual, shared, etc.
    Try TCP slave first.
    in reply to: On – Off Value Changes #4060
    Is there any way to change the Off-On command that comes preinstallated in the system so off means 4 and on means 8
    Yes, just use a formula for an output channel. For example: Cmd <= 0 ? 4 : 8
    in reply to: HourBeg Function #4059
    If you change it to == 0, the function may be executed before hourly data are stored in the archive. In most cases this doesn’t fit.
    How do you plan to use this function?
    in reply to: Modbus TCP over GPRS (S27x GPRS RTU) #4058
    What should be the right configuration in communicator for Modbus TCP protocol?
    This question is too general. Many configurations are right. One of the possible examples is included in the default configuration.
    in reply to: Export to Database Module #4054
    Thank you for the screenshots.
    Do the data are successfully stored in your database when you use Generator?
    in reply to: Export to Database Module #4044
    You should describe in details what you did, what you get and what you expect.
    in reply to: Numerical display is wrong #4042
    You should change the type of the channels to Real.
    Formula was needed for the ADAM input module. May be your module doesn’t need any formulas.
    in reply to: How to install scada on Raspberry Pi using Windows 10 IOT #4041
    I recommend Raspbian of the actual version. The step by step installation manual is included in the Linux distributive of Rapid SCADA.
    in reply to: Responsive Web Design #4040
    in reply to: Export to Database Module #4039
    You should check the log file of the module to find the cause.
    MySQL is owned by Oracle Corporation ))
    in reply to: HourBeg Function #4038
    This approach is useful to store values in the archive in the beginning of a new hour and then reset them, for example.
    You can write HourBeg2() with your own logic.
    in reply to: Responsive Web Design #4026
    The bug is fixed and the fix will be included in the next version of Rapid SCADA in August or September.
    Thank you for your help.
    in reply to: HourBeg Function #4025
    Where in the source code these lines are located?
