Viewing 15 posts - 4,246 through 4,260 (of 6,391 total)
  • in reply to: performance optimization #5607
    async/await are efficient when you wait for response via some external channel, like network. SetCurData writes to the internal buffer of Communicator, so this approach doesn’t improve performance in this case.
    I use a quite rapid device which refreshs at about 50Hz
    It’s better to use PLC to collect data fast and then download data as a block.
    in reply to: Create a Virtual Device using communication and OPC #5606
    Hi Dawn,
    I suggest Rapid SCADA 5.7.x
    On the 1st VM install all the apps.
    On the 2nd and 3rd install Communicator and Agent.
    As virtual device you can choose Martrikon OPC simulation server or use the included in Rapid SCADA KpSimulator.dll driver.
    in reply to: Auto-update Char #5602
    As I remember, only Chart Pro refreshes chart automatically.
    You should try Chart Pro.
    in reply to: Unknown device tags #5601
    You should try poll any addresses using Rapid SCADA. Some devices answer ILLEGAL ADDRESS, but others return correct response filling with zeros. If yours of the second type, you can find non zero registers.
    in reply to: Unknown device tags #5600
    Also try WireShark
    in reply to: Modbus TCP Server #5599
    Hi John,
    Sure. Any time. We provide high quality and competitive price 🙂
    in reply to: Auto-update Char #5594
    Do you use the default Chart plugin or Chart Pro?
    What is the version of the chart plugin?
    In browser press F12 and check the Console tab for errors.
    in reply to: Unknown device tags #5591
    Do you know at least a communication protocol? Is it Modbus TCP or other one?
    in reply to: Modbus TCP Server #5587
    Hi John,
    I researched for this, and I have’t found any free solution. We can develop such driver as a custom development by a contract.
    in reply to: Using Multiple VM Computers #5586
    You have 2 options:
    1. Install on RTU VM only Communicator which connects to the Server app of the main VM.
    2. Install on RTU VM full Rapid SCADA and use Rapid Gate.
    about a key that would be needed to use the Rapid Gate. How would this be obtained?
    Buy permanent key or use free trial
    in reply to: Modbus RTU comunication issue #5585
    Seems like hardware problem. What USB-COM converter do you use?
    We have Spanish section in the documentation. It needs to be updated. To work with it, you should register GitHub, fork the repository, make your changes and create a pull request to include them into the project.
    in reply to: New Rapid SCADA 5.7.0 Beta #5577
    in reply to: Modbus RTU comunication issue #5576
    May be other application uses the same port COM4.
    in reply to: Modbus RTU comunication issue #5575
    The log says that there are problems with a converter:
    2019-06-17 17:00:23 Open serial port COM4
    2019-06-17 17:00:23 Error executing the communication channel actions before session with a device: Error opening serial port: Access to the port ‘COM4’ is denied.
