Viewing 15 posts - 4,126 through 4,140 (of 6,391 total)
  • in reply to: KpModbusSlave #5944
    stats of device indicate “file not found”.
    If you can’t find out the cause, create a new topic and copy log of communication line.
    in reply to: KpModbusSlave #5940
    Currently, KpModbusSlave.dll doesn’t exist. We already included it in the Device type table, because we are going to release this driver in the next year.
    in reply to: Conditional Links #5938
    Visibility property exists for buttons only.
    If we found a sponsor, we can implement binding of any property to an output channel. This approach allows to control elements flexible.
    in reply to: Use of the buttons #5937
    If you face the error and can’t fix it, ask here.
    in reply to: Use of the buttons #5932
    I can help by providing the idea here on the forum. Also I can connect to your PC remotely and configure the system with you. The 2nd way is for a fee.
    You should do the following:
    1. Create an input channel of the Calculated discrete type. This channel stores the led state.
    2. Create 2 output channels for the buttons.
    3. Create a scheme to display the led and the buttons.
    4. Bind the led to the input channel and bind the buttons to the output channels.
    Use SetVal() formula in the output channels to set led state. More details about available functions is here.
    in reply to: Hyperlink between windows #5930
    Basic Components do not require any key.
    And all components work in Scheme Editor despite they need a key or not.
    I’m glad that now components work.
    in reply to: Hyperlink between windows #5927
    Please check C:\SCADA\ScadaSchemeEditor\Log\ScadaSchemeEditor.log
    There are information about loading components.
    in reply to: AT command GSM #5923
    Use Hercules to make sure that your modem supports ATE0 command.
    in reply to: Hyperlink between windows #5922
    Scheme Editor v5.2.3.1 is fresh. A Link component is installed by default.
    Scheme Editor looks for the components in C:\SCADA\ScadaWeb folder. Do you have Webstation installed?
    Video Link.
    in reply to: Connect files with input channels #5921
    You need to develop a driver that recognizes the file format you use.
    I suggest, import from a database that works out-of-the-box.
    in reply to: AT command GSM #5911
    The modem doesn’t respond. First of all, check serial port settings in Rapid SCADA.
    in reply to: Connect files with input channels #5910
    Do you mean to import data from the file to Rapid SCADA and show these data?
    in reply to: Hyperlink between windows #5909
    Watch the video about the editor to view all components.
    in reply to: Hyperlink between windows #5908
    There should be more components. What version of Scheme Editor do you use?
    in reply to: SNMP #5907
    Yes, this is a limit. Input channel values are stored in a “double”, which has 8 bytes.
