MikhailModeratorScreenshots would clarify the situation.
Please make screenshots of the input channels and the toggle properties.
MikhailModeratorError establishing TCP connection: No connection could be made because the target machine actively refused it 172.27.1.210:502
This message means that the PLC is not available by the IP 172.27.1.210 and port 502.
You should check the PLC.
Please provide a part of communication line log.
MikhailModeratorIncrease a delay or a period in the device properties (Communicator settings, communication line parameters, request sequence).
MikhailModeratorI confirm also work with latest version of
Great! Could you summarize what a user should do if he faces such problem?
MikhailModeratorIn this case, to be exact, you should search for a string ” – Rapid SCADA” in the *.js files.
The file you need is C:\SCADA\ScadaWeb\plugins\Table\js\table.jsUpgrading the software, we try to minimize the number of files where the product name is located.
MikhailModeratorTry downloading Newtonsoft.Json from NuGet and copy to /opt/scada/ScadaComm/KP
You need Newtonsoft.Json version >= 10.0.3
Does it help?Probably Mono on my Linux computer already contains it somehow.
Run file content search for “Rapid SCADA” in C:\SCADA\ScadaWeb
Replace what you find.
MikhailModeratorWhat is Mono version?
MikhailModeratorTry this file.
You should create directories:
/opt/scada/OPC Foundation/pki/app
/opt/scada/OPC Foundation/pki/issuer
/opt/scada/OPC Foundation/pki/trusted
/opt/scada/OPC Foundation/pki/rejected
/opt/scada/OPC Foundation/pki/issuerUser
/opt/scada/OPC Foundation/pki/trustedUser
and provide write access for them.
MikhailModeratorIn this case, you should use Automatic Control Module to send a release command. Use a trigger on command.
Is it important how long an operator keeps the button down?
MikhailModeratorDone. Thanks for noticing.
