Viewing 15 posts - 3,646 through 3,660 (of 6,391 total)
  • in reply to: How to send commands using KpMQTT #7457
    Good. Please post screenshot of a command form (in Administrator), so I can tell you how to send similar commands from scheme.
    in reply to: Server problem #7452
    I’m very glad to read that the system is reliable now.
    Anyway in the next version Rapid SCADA engine is totally new, and I hope there will be no more such errors.
    in reply to: How to send commands using KpMQTT #7451
    I wander how to send command using KpMQTT via the Scheme Editor
    Before sending command from schemes, you should check that commands are successfully sent from Administrator. Have you already done that?
    in reply to: Redundancy in the upcoming Version 6 #7447
    In current version you can deploy an extra instance of Rapid SCADA like we do in our cloud solution. Also you should provide ability to poll controllers in parallel. Implementation depends on communication protocols.
    in reply to: Redundancy in the upcoming Version 6 #7445
    Yes, it is. It will support redundancy of data archive.
    in reply to: How to send commands using KpMQTT #7444
    1. A sending commands form in Administrator is general. Implementation depends on a particular driver. If you already able to successfully send commands using Administrator, I can describe how to do the same from schemes.
    2. Is this a string to be parsed? Why do you send different values in a one topic?
    Screenshots would help to understand your task.
    in reply to: Webpage Connection #7438
    @jacklondon
    is right. You should allow incoming connection to the HTTP port 80 on the Windows firewall.
    in reply to: Server problem #7435
    Thank you for the details.
    Could you try another approach for the same thing?
    Do the following:
    1. Make inactive the existing watchdog triggers.
    2. Create a new trigger that fires “On channel data change”
    3. Create a similar command for the new trigger and tick “Copy value or data” checkbox.
    4. Don’t use “Out channel” in the trigger command, but use “Device” and “Command” fields.
    Please let me know about the result.
    in reply to: BACnet KP #7434
    Please provide an example what do you get after decoding an incoming BACnet message?
    May be I should apply the suggested updates, may be not. To do this I have to be sure that they are really necessary there.
    in reply to: PET-7060 Problems #7433
    My server is on 192.168.1.60 …. on this server machine if I put 192.168.1.60/scada/ in the search bar of Chrome it all works . If I go onto another PC on my network I can not connect at all …just get a connection time out
    Please create a new topic for this question, because it has another sobject.
    in reply to: BACnet KP #7426
    You can get a list, but you can find a device (KP) by a numerical address or string address (CallNum).
    Could you explain, how do you detect that an UDP packet is addressed to a particular device (KP)?
    in reply to: Server problem #7425
    Please make screenshots of the related output channels. I need to check their properties, especially formulas.
    in reply to: PET-7060 Problems #7424
    Try the links below
    https://sourceforge.net/projects/modrssim/
    https://sourceforge.net/projects/modrssim2/
    Does at least one of them work?
    in reply to: Server problem #7420
    Please check:
    Does the server stop responding in the same moment when Automatic Control Module sends a command? If yes, which output channels numbers related with the problem?
    in reply to: BACnet KP #7418
    kpLogic = CommLineSvc.FindKPLogic(...);
    // decode received data here
    kpLogic.SetCurData(...);
