Viewing 15 posts - 16 through 30 (of 6,403 total)
  • in reply to: OPCUA Server Certificate Period #18561
    The current version of the DrvOpcUa driver should generate certificates with a 10-year validity period.
    Please provide the additional info:
    – What DrvOpcUa version is used?
    – How did you check the certificate period?
    in reply to: Hex Command #18559
    Yes, you can. Please provide screenshots and logs of the values you tried to send.
    in reply to: Unreliable Data in Chart Plotting #18556
    The Server service sets the channel status to unreliable if there is no data longer than the specified period. That period can be set in the Server main options. By default, it is 300 seconds.
    You should try to find out why there are no data for 5 minutes or more from Rapid Gate.
    in reply to: New release Rapid SCADA 6.5.x #18555
    in reply to: New release Rapid SCADA 6.5.x #18552
    The installation file have been fixed.
    I need to start the services manually every time.
    This is weird. I suggest checking Windows Logs via Event Viewer. Maybe there are some errors.
    in reply to: New release Rapid SCADA 6.5.x #18332
    Thank you for the report. There is a bug in the installer.
    As a workaround, create an empty directory C:\Program Files\dotnet\shared\Microsoft.AspNetCore.App\8.0.0
    in reply to: Bit Reading #18328
    I suggest editing the Modbus template and setting the Bitmask checkbox for the element. Then generate channels by a wizard. It will create calculated channels with the required formulas.
    in reply to: Only Archive on “Status change” #18325
    Is there a way to ignore status, and only write on “value” change?
    Talking about writing to archive, there is no such an option.
    To solve the issue, let’s find why the status changes and avoid that.
    in reply to: Controlling Device Polling #18323
    It should be possible.
    In the Communicator settings, set the Poll only on command checkbox for each device on the communication line.
    Then make sure that you can initiate a single device request by a command. Right-click the device in the project explorer and click the Poll Device menu item.
    If the above works, we will figure out how to automate sending polling commands by some flags.
    in reply to: RTU500 AS 61850 SERVER #18322
    Perhaps, it would be more efficient to request ABB support.
    Trend is a simple component.
    To display a full featured chart, use the Frame component with Source Type = Chart.
    See ExtraCompTest.mim as an example.
    I suppose, it requires the configuration files for the chart plugin.
    A chart is displayed in a separate frame by the Chart or Chart Pro plugin.
    Please press 12 to open the browser tools, and check the frame URL, so I can provide more details.
    • This reply was modified 2 months, 1 week ago by Mikhail.
    However, when I set ArchiveCode=Sec in PlgChartPro.xml’s DataOptions, the chart page requests archiveBit=1 (Min) instead.
    It sounds weird. Try creating a new profile for the Sec archive.
    I confirmed it works – the channel’s decimal archive value becomes 65536 when only this archive is enabled, and I can retrieve correct data by calling the internal API directly
    An archive name is shown in the chart info in the top. What archive is mentioned there?
    In short, you should create a new chart profile. It is a file located in the Webstation configuration in the project.
    1. Copy the existing file PlgChartPro.xml with a new name, and specify the archive in the new profile (DataOptions – ArchiveCode).
    2. Edit PlgChartPro_Config.xml by adding a new profile.
    3. Upload the project for execution.
    in reply to: Communication error and reconnection #18306
    Try set the Disconnect on error checkbox.
