Viewing 15 posts - 2,971 through 2,985 (of 6,392 total)
  • in reply to: New Chart Pro settings, second YAxis #9410
    The both of the YAxis have the same QuantityIDs, so trends will be bound to the same axis.
    in reply to: New Chart Pro settings, second YAxis #9403
    You should add a new YAxis block into YAxes. It’s important to specify QuantityIDs for the added YAxis, because channels are bound to the axis according their quantities.
    in reply to: RS232 to RS485 converter #9402
    Will you develop a custom communication channel by yourself or prefer ordering the development?
    in reply to: RS232 to RS485 converter #9398
    This feature requires changes in the source code of the serial communication channel. In Rapid SCADA 6, which is not ready yet, it will be possible to develop a custom communication channel with the needed logic. However, may be it’s easier to change the converter.
    Is there any command or method to stop auto control module without stop/restarting scada server?
    Currently, no.
    Sometimes, e.g. during the maintenance check, I need to toggle/send cmds manually for testing, but then the auto control module will override my cmds on next update.
    Please explain or provide an example.
    in reply to: Auto control module settings #9396
    Thank you for the info.
    in reply to: Send command with button #9395
    As I understand your case, command should be sent by button click. In this case Auto Control Module is not required. But you should correctly set the Command Number and Device fields of the output channels. Device is related to the OPC server.
    in reply to: Send command with button #9394
    I recommend to change channel type of the channels that are set only from formulas to the Calculated Discrete (or Calculated Real) type.
    To send command according to some conditions and actions, Automatic Control Module is needed.
    in reply to: Send command with button #9383
    Screenshot of the input channel can be useful
    in reply to: Send command with button #9382
    The settings look OK. Check in ScadaServer.log that commands are received by the server app.
    in reply to: Scheme copy #9378
    except the content in the frame can not be loaded even for long long time
    Open browser tools by pressing F12 and check why the frame content is not loaded.
    Screenshots can help to find the cause.
    We will waiting for your next version to try.
    The issue is not related to a version.
    in reply to: Detect server restart when using the tcp socket api #9372
    Using Rapid SCADA client you can get file age of incnl.dat file. It is changed when configuration is uploaded.
    ServerComm.ReceiveFileAge() method
    in reply to: Disable password request on command #9371
    Yes.
    in reply to: Scheme copy #9370
    During installation for extra components, I have not meet “registration key”.
    Where to get it?
    After activating the plugin, look in Main Menu – Registration in Webstation
    in reply to: Scheme copy #9354
    Another method:
    Hold the Ctrl button and click the components to multiple select.
    Press Ctrl+C to copy components to the clipboard.
    Then choose Edit – Paste Special to paste components.
    Scheme Templates also good, but using many frames may affect performance.
