RS232 to RS485 converter
Forum Home Forums Communicating with Devices RS232 to RS485 converter
  • #9391
    MilanJo
    I use RS232 to RS485 converter with MAX232 and SN75176 chips. I want to use RTS signal for data enable on SN75176 chip.
    How do I set the RTS signal to be active only when sending data, for serial communication – modbus RTU over RS485?
    When I select the RTS option in “Serial Port Properties” – RTS pin on serial port is always active.
    thanks for help
    #9398
    This feature requires changes in the source code of the serial communication channel. In Rapid SCADA 6, which is not ready yet, it will be possible to develop a custom communication channel with the needed logic. However, may be it’s easier to change the converter.
    #9399
    MilanJo
    Thank you for your prompt response. We are looking forward to the new version of SCADA.
    • This reply was modified 4 years, 10 months ago by MilanJo.
    #9402
    Will you develop a custom communication channel by yourself or prefer ordering the development?
