If you have issues with displaying the above data, please provide screenshots.Can I export this excel data via WebStation?
Yes, Webstation allows to export historical data to Excel.
October 28, 2022 at 2:10 pm in reply to: V6, communicator ignores bound channel of integer data type #11455
MikhailModeratormaybe it should be highlighted in the document regarding these data types
You right. Currently, the documentation for v6 is not ready. Nuances of the algorithms should be added to the docs.
MikhailModeratorLet me try later today since I have my own Mqtt server locally and on the cloud.
@kumajaya, if you already have tried the MQTT publishing data source, could you share the experience?October 27, 2022 at 12:23 pm in reply to: v6, DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ? #11449
MikhailModeratorWriting of 0 data points completed successfully in 1 ms
It looks like no channels are associated with the archive.October 27, 2022 at 12:22 pm in reply to: v6, DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ? #11448
MikhailModeratorInfluxDB2 is supported.
In ScadaServer.txt there are statuses of archives. Is the MinCopy archive displayed as ready?In ScadaServer.log how many channels for archiving? For example
Number of active channels for archiving: 271October 27, 2022 at 12:11 pm in reply to: V6, communicator ignores bound channel of integer data type #11445
MikhailModeratorIn my test project, I setup 77 channels, all as Integer type, none got recognized, until they are all set to Double. and they all are immediately recognized by Communicator.
The Modbus driver uses the double type for all its tags. Channel data type must match a tag data type. The behavior looks as expected.
Currently all existing drivers use the Double type. However, if someone writes a custom driver, he can use integer tags.
MikhailModeratorScadaCommon.dll is a new name for ScadaData.dll
You can find new file formats here.
Do you use GitHub? If so, you could add the development to a public repository.
MikhailModeratorFor the ScadaWeb project try publishing to a folder.
October 26, 2022 at 11:16 am in reply to: V6, communicator ignores bound channel of integer data type #11428
MikhailModeratorCould you provide screenshots?
Is it possible to reproduce the issue on the default HelloWorld project?Data type of channel and device tag (provided by a driver) must match. It should affect only certain tag. If it corrupt other tags, it may be a bug.
MikhailModeratorIf you use PostgreSQL archives, pgAdmin converts selected data to local to make it handy for a user.
MikhailModeratorIt seems that rapidscada is using UTC time to store data
That’s right. Timestamps converted to local time only in the web application.
Log files uses the server’s time zone, however, it does not affect the logic.
MikhailModeratorScreenshots and logs may help.
I tested the MQTT data source with the following parameters:
ClientID = DataLifetime = 60 DetailedLog = False DeviceFilter = MaxQueueSize = 1000 Password = C8080E774B59B0C6694063BDE2428352 Port = 1883 ProtocolVersion = Unknown PublishFormat = QosLevel = 0 Retain = False RootTopic = Communicator/ Server = broker.mqtt-dashboard.com Timeout = 10000 UndefinedValue = NaN Username =Communication channel options:
ClientID = Password = C8080E774B59B0C6694063BDE2428352 Port = 1883 ProtocolVersion = Unknown Server = broker.mqtt-dashboard.com Timeout = 10000 Username =
MikhailModeratorsomehow my own build searching for dependency library in the current directory, different than official release from the root of Administrator app
What particular files, for example?
