Viewing 15 posts - 2,161 through 2,175 (of 6,391 total)
  • in reply to: ModDbExport for oracle #11939
    If there is an issue, the error is written in the module log. Could you check C:\SCADA\ScadaServer\Log\ModDbExport*.* ?
    in reply to: rapidscada V6 use CustomPage #11935
    Columns in the Views table (v6):
    Path – path in the explorer, for example, MyFolder\MyPage
    View Type = Web page view
    Arguments – web page URL
    Title – any text
    If it does not help, please provide link to a screenshot of the Views table and info from browser console.
    in reply to: V6 Status Severity #11931
    Check this document, page 2.
    in reply to: Event – Channel data and channel value #11928
    Channel data contains of value and status.
    The 1st option generates an event only when value changes.
    The 2nd option generates an event when value or status changes.
    in reply to: User management plug in #11927
    What user management plugin do you mean? Could you provide a screenshot?
    in reply to: v6 notification plug in #11926
    Can I use this notification management plug in temporarily
    Currently, there is no Notification Plugin for v6.
    in reply to: V6 plug in #11925
    Please find plugin descriptions in the Administrator application.
    in reply to: V6 Webstation Application Options issues #11924
    There is no Notification Plugin for v6.
    To acknowledge an event, click the ack checkbox in the event panel in the bottom of the page.
    Not all events can be acknowledged. It depends on event severity.
    in reply to: V6 Chartpro plug in #11922
    Could you provide error details?
    in reply to: Version 6 issues #11912
    all the configuration and set up must be done via Administrator
    Yes. This approach helps to avoid loosing the configuration changes.
    including the previous plug in authorization
    Which plugin do you mean?
    in reply to: v6 notification plug in #11911
    When we develop Notification Plugin for v6, you can upgrade the key for the same computer for which you bought the key.
    in reply to: V6 ENUM TEXT and formula at V6 #11910
    Please find enumerations in the Formats table.
    Please advise if the formula was named as script now?
    Yes. This was done to distinguish between channel formulas and general formulas.
    in reply to: Full Documentation Support for V6.0.0 RC #11909
    Any particular due dates may be specified only in a contract. Working on docs for v6 will be started after porting all modules, because we need to know the features of the modules, and make their screenshots for the manuals.
    Documentation for v6 will be at least as full as v5. I hope it will be more detailed.
    in reply to: V6 Format -Enumeration vs string #11908
    I think, using enumeration is better for this case. It is specified in the Formats table.
    in reply to: Remote port number – V6 #11907
    Options to specify communicating with devices are located in configuration of a communication line.
